Results 1 to 10 of 21
Thread: Is this a good price
    Michigan
    Default Re: Is this a good price
    Quote Originally Posted by falken View Post
    http://www.lesliespool.com/shopping/...roductID=13143
    http://www.lesliespool.com/shopping/...roductID=13151
    http://www.lesliespool.com/shopping/...roductID=13147
    Your total cost would be $17.22, considering the kit is on sale for $10.50 right now, I would do that.
    Ok, thanks! Now, a couple more questions. For the DPD Reagents, it lists #1, #2 and #3. But in the description box, it says you must use #1 and #2. Plus the pic of the kit itself only shows 2 bottles plus the powder. So do I have to get any of the #3?
    Also, this tests FC and CC? The site isn't clear exactly what it is testing. I've only used simple tests before.
    And if this tests for both FC and CC, why would one also need the OTO test? For the PH part of it?
    Thanks yet again
    Oops, forgot to ask.... can the reagents all be stored in the fridge to extend their life? If so, for how long?
    Why BBB? Because money can't buy happiness, but saving it sure can!
    Bucks County PA
    Thanks for all the info!!
    Michigan
    Sorry! I didn't mean to hijack your thread, but this seemed like the best thread to post my questions also!
    Michigan
    Quote Originally Posted by doggie View Post
    Thanks yet again
    Does anyone know the answers? Sorry to pester, but I want to get the stuff ordered while it's on sale, and I don't know which of the DPD reagents I have to have.
    Thank you.
    1st: DPD testing and FAS-DPD testing are NOT the same thing. With FAS-DPD, you add a scoop of powder to the water then use the FAS-DPD reagent 8071 to measure FC. You then add reagent 0003 to measure CC to turn it pink again and titrate with 8071. ( )
    For OTO testing you merely add the OTO (ORTHOTOLIDINE) fluid.
    OTO is much faster and quite accurate--but it's hard to get above 5ppm of total chlorine.
    FAS-DPD is slower but far more accurate measuring from .2ppm to 50 (or 100)ppm of Free Chlorine or CC. (Remember: TC = FC + CC.).
    It's hard to get the pH kit without either a DPD or OTO chlorine test, so getting the OTO is my recommendation--and it's not expensive anyway.
    Since I don't do DPD testing I can't tell you much about it, other than chlorine levels higher than 15 can bleach it clear!
    Doggie,
    DPD #1 is the powder, #2 and 3 are the liquids. #2 is used for both FC and CC testing , #3 turns the smple red when CCs are present. All 3 are neccesary. In Bens kit, the OTO is used for daily testing (only tests up to 5ppm) one reagent 5 drops - all set, it's just quicker when you don't have a problem where you need >5 ppm or need to know CC. Also, the pH test in Bens tests from 6.8 to 8.2 - the R004 only tests between 7.0 and 8.0.
    Poconos says that the reagents can be kept in the fridge indefinately without going bad.
    Hope this is in time for you to catch the sale!!
    Michigan
    Thanks so much guys! I appreciate it!
    Michigan
    Ok, I'm still confused.
    I want the Chlorine FAS-DPD Drop kit. http://www.lesliespool.com/shopping/...ProductID=9414
    That tests the free chlorine, total chlrorine and combined chloring, right?
    Then to get extra refils, it looks like all 3 of these are all drops http://www.lesliespool.com/shopping/...roductID=13147
    and that the powder not one of those 3, it's this http://www.lesliespool.com/shopping/...roductID=13143
    So that is 4 choices I have for refils, but the kit appears to only have 3 items in it.... 2 liquids and 1 dry powder.
    Also, the CYA test kit shows 3 different things, 2 liquids and 1 powder http://www.lesliespool.com/shopping/...ProductID=9414
    So since I'll use this one the most, I will need extra. What are the components there? Under reagents, for CYA I only see this one http://www.lesliespool.com/shopping/...roductID=13184 So what are the other 2 things in the kit picture?
    Sorry for these questions, but that site sucks as far as telling you whats included in the kits, and exactly what refils you need?
    Thanks so much you dear people
    Doggie, don't worry about asking the ?s - that's why were here. (BTW - congrats on your newfound seniority!)
    You need the powder and the 2 liquids for the cl tests, I believe that #2 and #3 are the same reagents whether you use the powder or the liquid for #1 (the liquid only measures up to 5ppm TC, the powder can go to 50.
    The cya I saw on their site was # 18563 which shows the mixing bottle, 2 bottles of the test reagent (they are both the same - you only get ~3 tests per .75 oz bottle, so they give you 2) and what looks to be the instructions (the square packet) and the test chamber.
    If you want to know what other back-up reagents to get I'd say a large (2 oz) bottle of R-0010 Calcium buffer (CH test reagent #1) - the cal test takes 25 drops of this per test and R-0012 Hardness reagent (CH test #3) (1 drop = 10 ppm, so if you have high calcium, you can go through it quickly if you test cal weekly - which you probably don't need to do)
    A back-up bottle of R-0009 Alkalinity reagent would probably be advised as well (again 1 drop = 10 ppm, so with an alk of 100, you'll use 10 drops/week)
    If you want to get more of the cya reagent, it won't hurt- as I said you only get 3 tests per bottle and though you only need to test it a couple of times a summer (after you get the level where you want it) but as I said above - you kan keep the reagents in the fridge and might as well get it all at once as long as you're already paying shipping.
    I hope that this is a little clearer than the website
    Michigan
    Very helpful dear. Thanks much!!!
  1. Bleach vs Chlorine price
    By kelemvor in forum The China Shop
    Last Post: 03-09-2012, 07:50 PM
  2. Best price for CYA?
    By MikeInMo in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-14-2007, 10:08 AM
  3. Muriatic (HCl Acid) - Price !
    By Katy-Texas in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 04-25-2006, 05:01 PM
  4. Polyquat price
    By griggers in forum Dealing with Algae & Slime
    Last Post: 04-20-2006, 11:14 PM
