Results 1 to 10 of 13
Thread: If money were no object
    Jul 2006
    Default If money were no object
    what is the best automatic pool cleaner money can buy? (just short of having a pool boy/girl living in your backyard )
    Default Re: If money were no object
    Quote Originally Posted by CanuckPool View Post
    CP, if it were me, I'd have an 18 yr old Sweedish girl doing the pool, and hope my wife diddn't figure out why I spent sooo much time poolside
    fcfrey is offline ** No working email address ** Thread Analyst fcfrey 0
    Central PA USA
    I have had three different pool cleaners:
    Manual vacuum brush on the end of a long hose ---Pain in the back!!
    Dolphin Diagnostic $700 ---- Got stuck on everything and damaged my liner
    Aquabot T-4 $1500 ---- wish I had started out with this!!
    The T-4 is by far the best cleaner IMHO --- with the remote and high speed plus add in the random turns and horizontal action even on the side walls, you can't beat it. So far service turnaround has been less than 2 weeks (I damaged the cord [They fixed it as warrantee] just had to pay shipping 1 way)
    Fcfrey,
    What kind of shape is your pool? I am trying to decide whether to spring for a robot for my pool. Just want to be sure on the performance before I make a decision. Someone on another board had nothing but praise for the dolphin.
    62,800 Litre IG Vinyl
    1HP Super Pump
    Clearwater LM2-24S SWG
    250K NG Heater
    Mars HP Pool Sweep
    Central PA USA
    Quote Originally Posted by caustik View Post
    Fcfrey,
    I have a 42x25 true ELL with hopper bottom and rounded corners here's a link to an old pix but you can see the shape.
    http://i129.photobucket.com/albums/p206/fcfrey/Pool.jpg
    The T-4 cleans the entire pool in an hour or less and I do not have to play nurse maid to it, as a matter of fact, I put it in today (under the loop lock cover) I don't have to worry about it hurting anything or getting stuck. I had a Dolphin which according to the instruction manual can't be used under 65 degrees. There is no temperature restriction with the T-4. The pool water was 46 today. Too cold for me but not the robot!!
    hzz is offline Lifetime Member Thread Analyst hzz 1 star
    Toronto Canada
    That's one thing about Aquabot products-they will work in very cold water.
    The dolphin will not. Below about 65 it doesn't move around.
    Quote Originally Posted by fcfrey View Post
    . . . I had a Dolphin which according to the instruction manual can't be used under 65 degrees. . . .
    Will you, or anyone else, please confirm this quote. I am considering buying a Dolphin Diagnostic Sprite Robotic Pool cleaner and e-mailed an online store (http://www.bestbuypoolsupply.com/dol...leaners-2.html) and the technician responded saying he'd never heard of the temperature restriction. Maybe there is a difference in models. Here in the NW the pool is often below 65 deg F.
    Thanks for replys,
    Roger
    mas985's Avatar
    Pleasanton, CA
    Quote Originally Posted by waste View Post
    Just the pool?
    Mark
    DFW Texas
    Quote Originally Posted by mas985 View Post
    Just the pool?
    I like the way you think!
  1. Saving money on salt
    By famousdavis in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-07-2013, 03:32 PM
  2. Throwing money at Algae, still not gone :(
    By Waterboy in forum Dealing with Algae & Slime
    Last Post: 09-08-2012, 06:32 PM
  3. so ... if mps is a waste of money ...
    By Berggy in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-11-2011, 10:58 AM
  4. Best salt generator for the money?
    By skos007 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-06-2011, 12:25 PM
  5. pool rover, anyone used it and is it worth the money?
    By chuds in forum Pool Cleaning: Manual or Automatic
    Last Post: 07-20-2006, 09:40 PM
