Results 1 to 9 of 9
Thread: chlorine effects on treated lumber
    Oct 2004
    Tallahassee, Florida, USA.
    Default chlorine effects on treated lumber
    have a friend who told me his deck (treated lumber) started popping boards after some time due to chlorine. Anyone have input on this, as I am getting ready to build a deck on long side of 18 x 33 oval. Also, if anyone has plans for a side deck for same size pool if you could guide me to such or pm me it would be appreciated.
    Lafayette, IN
    Default Re: chlorine effects on treated lumber
    Our deck is three years old and I use chlorine. No pop-ups at all. Our deck has screws and no nails in the decking or the railing. You can see a picture of our deck under the thread: "Winter Woes". Granted, it's for a 24' round, but the plan can be easily modified.
    I would agree that splashed water from the pool onto nails in a wooden deck will corrode them over time. A salt pool (i.e. SWG, though some people add salt without an SWG) will likely corrode such nails faster. In either case, the use of high-quality galvanized nails should help, but as was pointed out the use of screws is even better.
    Did the popping of the boards happen due to corrosion of the nails themselves? That's what I would assume, but if it's due to some sort of breakdown or expansion of the wood itself or possibly loss of friction between the nail and the wood, then it would be useful to know that. Also, did your friend have an SWG or pool with added salt? Just trying to keep some statistics on this one way or the other.
    Richard
    Oct 2004
    chem geek, no salt added as far as I know. He did say the boards popped from nails, so I'm guessing they weren't galvanized. He no longer has the pool or deck so can't get a totally accurate story, but that is what he can recall. Thanks for the advise, I think I'll go with the deck screws and hopefully I won't have any problems.
    Morris, IL
    In my honest opinion, go with synthetic wood decking too. I have come to the conclusion that wood is pure garbage, it warps, twists, curves, and does a million other things that I never want it to. I am seriously into not using wood for construction anymore. Of course the uprights and bracing I probably will, although if I find that there is an alternative to that then it is possible I would use synthetic there too.
    But, screws for sure, nails outside are a temporary solution installed in a permenant manner. You cannot pull them easily, and they never really seem to stay put. Screws on the other hand, can be easily removed, and they tend to stay put.
    Hi, I could not agree more with sevver, synthetic wood and deck screws are the way to go. I have built many decks here in Arizona with Pine and deck screws. Never a problem with chlorine or boards pulling up but they do need to be restained yearly. Synthetic is so much nicer with less maintenance.
    Later, Dennis
    My immediate deck is made of the hollow panels that function as the solar panels, but all the fencing is cedar. If you can manage it, stainless steel screws and/or nails are extremely resistant to corrosion. With cedar you really have no other choice anyway, except perhaps ceramic-clad screws.
    Wood decks require maintenance and periodic replacement of floor boards no matter what. It's just the nature of wood decks.
    Mandeville, LA, USA.
    My bet is that the nail pops are the result of an improper fastener choice; either the type or the size.
    It's extremely unlikely that a little pool splashout is the cause, especially when you consider that many (read millions) of properly constructed wood decks are constantly exposed to rain, snow, and sunlight in non-poolside applications with little to no adverse effect.
    We are putting a deck on our 18x33 but only on one end. We picked up our materials Friday. We chose composit (Choice Dek) but there are tons of other brands out there - Trex, etc. The point is I don't WANT to have to treat boards every year or even every few years, like I do my house deck. The screws that we purchased are all stainless steel. But, all composit deck materials require treated wood for the framing/base. So you still have some exposure there. The surface boards are the ones I am most concerned about having exposure to lots of moisture and chemicals. Thats why I chose the composit. Cost more, but will be worth it. BTW, choosing your railing options is what puts the cost over the top - The cost more than doubled depending on what we chose for rails. You can still go with treated wood for railings to keep the cost low - we will be painting the rails with a bit more expensive "lifetime" paint so we won't have to paint them for another 20 years. The composits come in various colors so you can go decorator colors to match your house or whatever.
  1. Salt in non swg pool (long term effects?)
    By sunlove in forum The China Shop
    Last Post: 06-06-2012, 10:35 AM
  2. Effects of rain on pool chemistry?
    By savdoc2 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-27-2011, 02:59 PM
  3. Muriatic Acid effects on TA
    By DennyB65 in forum Dealing with Alkalinity and Calcium
    Last Post: 05-11-2009, 11:46 PM
  4. Effects of PH
    By NiteSwimmer in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-05-2007, 09:19 PM
  5. Can you taste and feel SWG treated water?
    By aquarium in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-22-2006, 03:28 PM
