Thread: Relocate pool light junction box?!?
    Default Relocate pool light junction box?!?
    I need to relocate the pool light junction box. The new location will be about 6' away.
    There are 3 conduits that come out of the ground and into the little black box that has BWF MFG on the cover. One steel conduit heads toward the equipment area, a brass pipe goes to the light in the pool, and the third leads somewhere else...maybe to one of the other lights (SAM) in the pool or spa.
    Here's my question. Do I need to pull new wire from all 3 areas back to this box, or can I somehow bury this junction and reroute it up in the new location?
    Default Re: Relocate pool light junction box?!?
    n2n, welcome (back) to the forum! While you can put another junctionbox wherever you'd like, burrying the origonal may violate local codes which require such connections to be a specified heigth above the pool water.
    If 2 of the feeds are from lights in the pool, I strongly doubt that the installers left you the extra 6' you'd need to completely rerout them. If only 1 is from the pool and spa, you may be able to do it if the location was closer to the source (if the other 2 lines attatch to power source and something not in the pool (say deck lights)), the only one that needs to be X" above the pool is the lights.
    I don't know why you want/ need to move the current ( ) box, but find out what the local codes are for pool lights and then you can better decide if it's possible - you can leave the existing box there and move the connections wherever you want (using the existing one as a 'feed'/ connection point for the other), but it sounds like you want it out of the way for something else.
    I'm not an electrician, but SAFETY FIRST!!, you don't want to possibly electrocute anyone who uses your pool!
    If I can be of further help or clarify something in my response, let me know
    When the pool was built, I needed to tell the builder where to put the elevated box.
    I had planned to have it six inches from a future add-on. I The room addition plans changed thus leaving the box about 6 feet out into the yard.
    I'm going to take your advice and check the code tomorrow, hopefully there is an easy or inexpensive solution.
    thx-
  1. CFL Pool Light Conversion & can't seal American Products Pool Light
    By DrBAF in forum Pool Equipment & Operations
    Last Post: 09-11-2012, 11:09 PM
  2. Pool Light Junction Boxes
    By Anderson in forum Commercial Pool Users, Managers & Workers
    Last Post: 08-15-2012, 06:11 PM
  3. Pool Light Junction Box
    By waldreps in forum Pool Equipment & Operations
    Last Post: 08-04-2012, 02:28 PM
  4. Pool light junction box
    By pumpkineater59 in forum Pool Equipment & Operations
    Last Post: 08-05-2008, 09:39 AM
  5. Cutting main drain line to relocate equipment
    By JohnT in forum In-Ground Pool Construction and Repair
    Last Post: 05-08-2007, 09:57 AM
