Setting up pool today, some of u might remember last year's arguments with DH about two panels staying hot (ie, no water flow thru them). to prove his point today, he had me look into each header pipe of each panel, to show me the center baffle, or diverter, where the water pressure should force flow up into the panel. i could see that the diverters are NOT solid, but have smaller holes in order to send part of the water up thru the panel, and not create immense back pressure. (Sort of like a washer placed in the center of the header pipe) is this right? or should the baffles CLOSE off water flow through the header pipe COMPLETELY until it makes a u turn and comes back through the panel? One of our panels has NO baffle AT ALL????? Could this have been last year's problem? i read that solar panels made for in ground pools have no baffles at all. i heardthat sometimes they can fall out and get lost. does that mean the panel is now useless? If not, can this panel still be used in conjunction with the others? should i replace it? is there any way to repair it? guess i need a class on "solar pool heat 101".![]()
