The eraser trick works well for card edge connectors but the switch contacts are too close together. I posted a pic in the thread I referenced earlier in post #5 of this thread. Back end of a Hayward pump motor. A cheap set of jewlers files will work fine. Otherwise some 400 grit wet-or-dry sandpaper, available at auto stores, works well. Again, you don't need to grind any material off. Cut a strip of sandpaper, double it up as in double-sided, and pull it through a couple times with slight pressure on the contacts, and that should fix it.
