Thread: Cleaning calcium from filters
    bizbad is offline ** No working email address ** bizbad 0
    Dec 2005
    Default Cleaning calcium from filters
    My pool company just acid washed my pool walls while the water was still in the pool to remove some odd stripes from the marcite. My cartridge filters now have white scale stuck to them. I was wondering if a soak in dishwashing detergent would be enough to remove the deposits that I believe to be calcium from the pool walls. Washing with a garden hose isn't enough.
    mas985's Avatar
    Pleasanton, CA
    Default Re: Cleaning calcium from filters
    If you can't get if off with the hose, you can try soaking them with a bit of acid. 1:5 ratio should do it but you can go stronger if needed.
    Mark
  1. Anyone tried one of these filters?
    By Bosch232 in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 09-20-2012, 02:12 PM
  2. Cleaning Solution for Unicel filters
    By RedwingT in forum Intex-type Pool Setup & Operations
    Last Post: 08-31-2012, 06:07 PM
  3. calcium hypo vs. calcium chloride
    By Oclat in forum Dealing with Alkalinity and Calcium
    Last Post: 06-04-2010, 05:06 PM
  4. 2 filters or 1?
    By tropic in forum In-Ground Pool Construction and Repair
    Last Post: 04-16-2010, 09:25 AM
  5. How much calcium in calcium-based shock?
    By cleancloths in forum Dealing with Alkalinity and Calcium
    Last Post: 06-04-2006, 04:58 PM
