Results 1 to 10 of 10
Thread: Plumbing Fitting for automatic pool cleaner
    Lightbulb Re: Plumbing Fitting for automatic pool cleaner
    Al, your ingenuity and resourcefulness never cease to amaze me! What you've made here is a DIY 'pipe extender' (sorry, no pic but found them online at:
    http://www.plumbingsupply.com/pvc.html#spigot ) They are an interior slip by 'outer pipe diameter' coupling just long enough to take a standard slip fitting - very! useful when you don't want to have to install a whole new fitting or valve. If you cut your pipe to 1.25" you could glue a F/A to be flush to the wall (only the F/A sticking out). I will point out that using one of these reduces the interior size of the pipe, but in a pinch - you gotta do what you gotta do. Ooops, I just noticed that with Al's, you'd need to use a 1.25" to 1.5" bushing to attach a standard 1.5" F/A.
    gdubs, welcome to the forum! As you can see, we will go to great lengths to help each other (including going out to the shop to 'hack up' and photograph a peice of pipe ) If you don't have all the tools to reshape a peice of pipe, you can find them {edit - pipe extenders} online (I'm sure that the link I gave is not the only place to find one - knowing that they exist is the starting point for comparative shopping) Before gluing anything into the 'return', double check that you need to (the old owners might have left the attachment fitting you need), and be sure that it's a return driven cleaner -as mas pointed out. Run the pool a few times and see if the cleaner will work without permanently having something stick out into the pool - or if you can contact the old owners, ask them what they used.
    There is also the chance that the link I provided has a F/A that will also connect to the ID of a 1.5" pipe (I gotta look that whole site through- they've got some funky and potentially useful fittings ) No one where I work had ever heard of 'pipe extenders' until I had the secretary order some - who knows what fittings exist that I don't know about!?
    Good luck with your quest, please keep us informed (& sorry about the kabitzing ) - Waste
    Honesdale PA
    Default Re: Plumbing Fitting for automatic pool cleaner
    Mark is right. I missed that one about pressure side. Brain focused on suction and that was it. Still may work though. I've used a 1.25" poolhose and a homebrew nozzle as a deluge gun for kids or washing the solar cover, hooked together with slip joint PVC like I suggested and very seldom blows apart. The sanding does rough up the surface and it may work. What have you got to lose?
    Al, thanks for your help. I went to home depot and purchased a 1.25" fitting w/ 3/4" fpt. I rigged it up to my cordless drill, and filed it down until it fit inside the 1.5" pipe. I tapped the fitting into the return pipe, until it was a tight fit. I purchased a jandy ray-vac, which has 2 connector options, 1.5" or 3/4". I connected the 3/4" connector to my homemade fitting, and it worked perfectly.
    It was a simple solution, but i wouldn't have thought of it without the help of this forum. Thanks for all your help.
    gdubs
    Honesdale PA
    Great.
    I just love happy and cheap endings.
  1. Building Pool Need Automatic Cleaner Advice
    By ladyvalk in forum Pool Cleaning: Manual or Automatic
    Last Post: 09-12-2011, 10:38 PM
  2. Please advise on my automatic pool cleaner
    By janmo in forum Pool Cleaning: Manual or Automatic
    Last Post: 06-15-2009, 12:52 PM
  3. automatic pool cleaner
    By KPROMERO in forum Pool Cleaning: Manual or Automatic
    Last Post: 05-23-2008, 01:51 AM
  4. Automatic pool cleaner by Frontgate....
    By cruzmisl in forum Pool Cleaning: Manual or Automatic
    Last Post: 05-27-2007, 11:51 PM
  5. What automatic cleaner for AG pool?
    By AnnaK in forum Pool Cleaning: Manual or Automatic
    Last Post: 08-07-2006, 07:19 PM
