Results 1 to 10 of 26
Thread: Can't Get Clear (Have PS233 Results)
    Sherra is offline Lifetime Member Weir Watcher Sherra 0
    South Carolina, United States.
    Default Re: Can't Get Clear (Have PS233 Results)
    If fc + cc + tc why is my reading lower which is more important.
    I'm guessing that was just a type-o. FC+CC=TC So, if your FC is 3 and your CC is 0 then your TC will also be 3. The CC is important because if it's more than .5 then you need to bring your chlorine up to "shock" level (depends on your CYA level) to get rid of the "useless" chlorine.
    Sherra
    Kershaw County South Carolina
    (previous AG pool owner)
    Frederick,Md
    Thanks it was a type-o. What i need to know is since my cya is 100 and I need to have my level between 5 and 8 and the test kit only goes to 5, should i depend on the fc reading. When i ran my test fc was 3 and tc was 2 why are they not the same??
  1. PS233 Results
    By aswetich in forum DPD-FAS based testing
    Last Post: 09-16-2006, 02:11 PM
  2. My PS233 Results and Questions
    By errodr27 in forum DPD-FAS based testing
    Last Post: 08-03-2006, 04:50 PM
  3. PS233 Results--Your input please!
    By SandyDittmer in forum DPD-FAS based testing
    Last Post: 06-12-2006, 10:46 AM
  4. results with PS233 with questions(of course)
    By marocema in forum DPD-FAS based testing
    Last Post: 05-19-2006, 07:00 AM
  5. First PS233 results of the season
    By bassadict69 in forum DPD-FAS based testing
    Last Post: 05-06-2006, 02:48 PM
