Yes another pool build! Mine has just started and thought I would post some pics.
SPECS:
95 Perimeter - Approx 467 sq ft Surface Area
14,500 Gallon Pool (need to remeasure as I made it bigger than the original 85' at layout)
750 Gallon Spa
3.5' to 5' to 4' Pool depth
SPA
8ft Spa - Raised 1ft
51 Sq Ft Surface Area
5 jets - 100w light
Air Blower
Paramount MDX Safety Drain
12" Thick Gunite Wall between Pool and Spa
PLUMBING
Pressure Testing all Plumbing Lines and Connections to 35 psi minimum
Poured in Place Steel Reinforced Concrete Pad for Pool Equipment
Paramount MDX Dual Safety Main Drain with ADR under deck Canister
Surface Skimmers (2) with Separate Runs to Pump
Auto Fill System
4 - Surface Returns
STEEL
½” Rebar 4-Bar Box Bond Beam around pool perimeter
3/8" Rebar 8" OC continuous on walls and floor
3/8" Rebar Deck Dowels for continuous tie in to deck
EQUIPMENT
Pentair 420 sq ft Cartridge Filter
Pentair Intelliflo 4x160 Multi-speed pump
Pentair EasyTouch 4 Control System
Pentair EasyTouch Wireless Controller
Pentair IntelliChlor IC40 Chlorine Generator system
Pentair MasterTemp Low NOX 400 Heater
Pentair Legend Platinum Cleaner with 3/4 HP Pump
Pentair 320 Erosion Chlorinator & Paramount Ozone System
Polaris Air Blower for SPA
(2) 300 Watt Pool Lights
GUNITE
Gunite Structural Pool Shell with 6 sacks to the cubic yard, including: 6" thick walls and floor, 8" thick coves
Transferable Lifetime Warranty from Gunite Company
Up to 36' Steps in Shallow End of Pool
TILE & COPING
Flagstone Coping
6" Waterline Tile
Overflow Vent in Tile Line
INTERIOR FINISH
Wet Edge Primera Stone with 10 year warranty
DECKING
All Concrete Decking to include #3 @ 16" OC steel reinforcement tied to steel form gunite shell,
with 4" minimum thickness, polyfoam layer between deck and bond beam and deck piers at deck perimeter.
Deco Seal at joint between deck and coping
SUNDEK surface with Flagstone inlays
620 Sq Ft + Planned
CLEAN UP/START UP
Clean up of construction debris, berm soil around pool and fill in tire tracks in yard, powerwash/scrub driveway & street
Initial Equipment Start Up, Chemical Balance
Pro Test Kit, Leaf Net, 16' Telescopic Pole, Brush, Chemical Balance
Pool School with Written and Verbal Instructions for Pool Operation, Maintenance and Chemical Balance,
Lien Waivers/Warranties signed from all sub contractors
Overhead View
Table View
Right Side of Yard
Middle of Yard
Left Side of Yard
More to follow...
