Thread: does it work??
    Default does it work??
    Does it work?
    Worth the investment?
    Yes I am a newbie
    Grecian 17'x33' Vinyl liner pool
    ZeoBrite filteration
    SWG Aqua-rite
    Sta-Rite Dura-Glas 1.5hp pump.
    SAM Light
    21037.5 gallons
    Dec 2005
    South Carolina
    Default Re: does it work??
    I've got one and it does help catch more junk on the first pass by the skimmer. Pretty flexible as far as depth and angle are concerned and its very easy to remove for swimming.
    My pool is 16x32 rectangular, one deep end jet across from the skimmer, one shallow end jet on the same side as the skimmer, one jet in the walk in stairs, and I turned my automatic cleaner port into a fourth jet/fountain to help aim surface garbage towards the skimmer.
    If you have a robotic cleaner, you'll need to remove the paddle before running it as the robot will knock it off into the deep end
    Nater
    I bought one several years ago, but didn't use it much. It didn't fit well into my skimmer opening. I would find it laying on the pool floor under the skimmer all the time, so I quit using it.
  1. Scopes of Work
    By Cyoungan in forum --cleanup--
    Last Post: 06-22-2013, 09:18 PM
  2. Will this work?
    By HOF-City in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 06-15-2012, 08:41 AM
  3. I am at work and need help...
    By beaming90 in forum Above-Ground Pool Construction & Repair
    Last Post: 07-17-2010, 02:20 PM
  4. solarchlor does it work ?
    By dp_vegas in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 04-21-2007, 11:06 PM
  5. Do these work well together?
    By denanbob in forum Above-Ground Pool Construction & Repair
    Last Post: 06-14-2006, 11:32 PM
