Thread: My pool looks like it will collase
    Jul 2006
    Default My pool looks like it will collase
    Hi
    I have a 24' round above ground pool. It is February in NH and our pool liner is so weighed down and the inflatable pillow has collapsed.
    It looks like the water level is below half and the cover is almost all the way in the pool. Some of the sides look indented.
    Do we add water or just undo the cover at this point, I think it is so heavy it causing too much stress on the walls.
    Thanks for your help
    Default Re: My pool looks like it will collase
    Quote Originally Posted by jackiesmom View Post
    Hi
    Whether you add water or undo the cover, you need to do one or the other soon to relieve the inward pressure on the walls before it ruins your pool. I personally would just take the cover off. Debris in the water is a lot easier to deal with than ice damage.
    Jul 2006
    Default Re: My pool looks like it will collapse
    OK so we took the cover off - the pool is only a quarter full and frozen solid.
    We have the hose in it now to add some water and we will deal with getting the cover out in the spring, it is too heavy to ge out now.
    Do you think this is OK? Is adding water now going to do more damage?
    thanks again
