Thread: Hey Sean! Re: Pool Pilot
    DONNIE is offline Registered+ Thread Analyst DONNIE 0
    Jul 2006
    Oklahoma
    Default Hey Sean! Re: Pool Pilot
    Our air temps are finally going to stay above freezing and my water temp is at 58F and will continue to go up. I hooked up my SWG this morning, set the power level to 1 and adjusted the purifier level. My purifier level will not adjust past 31% though. The arrow up button stops it at 31% but I want to start it at 50%. Am I missing something?
    Donnie
    9000 Gallon Fiberglass IG / Sta-Rite pump,cartridge filter & heater / PoolPilot Dig 220-36 SWG / Testing w/K2006
    Jul 2006
    Oklahoma
    Default Re: Hey Sean! Re: Pool Pilot
    Ok. Left it at 31F and 3 hours later it was at 61% on its own. I was able to adjust it to 50% at this point. Is that normal?
    Dec 2005
    South Carolina
    I've got a DIG-220, and your description sounds similar to the way my unit operates. As a word of caution, if you have a high % selected with low water temp, you could easily find the unit at 100% output as the water warms up. The unit has internal calulations to keep your Cl output constant at variable water temps.
    I installed my unit in late Feb 2 years ago, and had very high CL levels for a while by doing what you're describing. I adjusted the output to a low level until the water warmed up enough to keep output stable (mid 60's?). After that happens, you'll get a better idea of where your FC level goes vs. the output on the controller.
    Nater
  1. Sean I need help - Pool Pilot Total Digital
    By smallpooldad in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 08-16-2008, 01:17 PM
  2. Autopilot Questions for Sean
    By msjulian in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-07-2007, 02:51 AM
  3. Pool Pilot
    By DONNIE in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 08-11-2006, 04:07 PM
  4. Sean - Auto Pilot - Please Help
    By vsalvi in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 08-03-2006, 12:35 PM
  5. Question for Sean on High pH with AutoPilot
    By CAL7 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-03-2006, 12:20 AM
