Results 1 to 10 of 50
Thread: Looking for Advice - Possible SWG Convert
    Dec 2005
    South Carolina
    Default Re: Looking for Advice - Possible SWG Convert
    Of course I'm partial to the unit I own, the Autopilot DIG-220. No issues so far, and Poolsean here at the forum is a great and honest source of information and support (he works for Autopilot). The Autopilot has two programmable on/off timers, shows temp and salinity level on a digital display, has freeze protection, controls the pump, has capability of adding an ORP system and automated pH control loop if desired. I scoured eBay for 3 months and finally found a great price on my unit from a priviate party (about the price of a replacement cell).
    However, several other forum members (Waterbear) appear to have good luck with other model types. Do lots of homework to compare price/features for your needs and buy from a reputable vendor and I think you'll be happy with any choice.
    Nater
    Quote Originally Posted by nater View Post
    I went with the Goldline Aqualogic PS-8 since I wanted the automation also and at the time it was the only automation unit with an integrated salt cell controller. I am not sorry that I did. I LOVE it and it works flawlessly! (Only regret is that I did not upgrade to the PS-16. I now know what I could have used those extra relays for!)
    However, IMHO, the PoolPilot Digital has the best bells and whistles. It is not the easest unit to set up for a novice (and DO NOT trust your dealer to get it set up right for you. I have seen just too many improperly set up units installed by very reputable pool builders!) nor is it among the less expensive ones but once you get over the learning curve it is very easy to operate and has some features that make it one of the best choices out there and worth every penny! Bottom line, even some of the less expensive and fancy units like the Resiliance and the Zodiac work quite well at generating chlorine for your pool.
    mas985's Avatar
    Pleasanton, CA
    Ditto with what Waterbear said. I was purchasing a controller anyway and the SWG was only $400 more so it was a no brainer for me. I would easily pay for that in chlorine over the life of the cell.
    The Aqualogic is pretty a good value and had everything that I needed. But the main reason I went with the unit is because all of my equipment was Hayward and so is Goldline so I got an extended warranty for free.
    Mark
  1. Convert to SWG?
    By MartyW in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 03-27-2013, 07:51 PM
  2. bbb convert
    By 85gtr in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-07-2012, 11:39 AM
  3. It's my turn to convert...
    By JayC in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 05-25-2008, 06:05 AM
  4. I Want To Be A B/b/b Convert!!!
    By 2dogpool in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-17-2006, 11:47 PM
  5. Should I convert to 2-speed?
    By salinda in forum Pool Equipment & Operations
    Last Post: 05-03-2006, 01:29 PM
