Results 1 to 10 of 58
Thread: Steve's pool build status - Work started 2/19/2007!
    skamp is offline Registered+ Thread Analyst skamp 0
    Cypress, TX
    Default Re: Steve's pool build status - Work started 2/19/2007!
    Quote Originally Posted by huskyrider View Post
    Congrats, everything is looking great and your on a really good turn.
    If I were to point out anything I'd object to, as a contractor, it would be your posts.
    An ACQ 60 4"x6" post could have been incorporated into your covered porch and then wrapped with Hardee siding or Western red Cedar. It would finish a lot cleaner than the treated pine posts that currently hang out further than your beams.
    If you were to wrap the post now they would finish out much wider than the beam. I'm not knocking the way they did it, but I'd encourage you to have them trim the top up to the soffit to make it a little more eye appealing than the way it is now. The 6x6 post butting up to and hanging out wider than the 4" beam just has a rough uncompleted look to it. This will be much more noticeable after painting than it is now.
    just my .02
    See ya,
    Kelly
    Kelly,
    The 6x6 beams are going wrapped in a 15" brick column. I left 5 1/2" between the post and the gutter downspout. If I was going to have exposed beams I would have done it very different. I had to wait until the deck was done for them to do the columns. Thanks!
    Cypress, TX
    Days 25 & 26 - 3/16 & 3/17
    We had some rain on days 23 and 24 and that delayed the Pebble Tec install.
    On Friday 3/16 the rock guys started work on the flagstone inlays, firepit and bench. On Saturday 3/17 the Pebble Tec got installed and the outdoor kitchen was delivered.
    Firepit and bench in progress - You can see some of the inlays to the side of the fire pit but they are covered in stone dust.
    Another shot of the fire pit and bench
    Setting up for the Pebble Tec. This was very cool to watch. They had ropes running the length of the pool to hang their water sprayers and rollers.
    Spraying it in
    Washing off the mortar to expose the pebbles.
    Continued in next post
    Cypress, TX
    There she is waiting to get acid washed.
    Closeup of the tanning ledge
    Here is the outdoor kicthen. It still needs to be assembled and leveled. Once that is done the countertop and stone work needs to get done.
    View from the back. It will have a grill, fridge, sink and side burner. It came on 3 pallets and weighed 1290 lbs!
    Today they are acid washing the pool and starting the fill. It is getting close now.
    Northern Kentucky
    I think your outdoor kitchen is bigger than my ONLY kitchen!!
    Looking great... betcha can't wait for summer!!
    ~Grace
    Avid reader of this forum
    but alas, no pool... yet!
    Cypress, TX
    Quote Originally Posted by GraceByDesign View Post
    The sad thing is it is bigger then mine as well. The outside of my house is now much nicer then the inside!
    Jul 2006
    Pearland, TX (Houston suburb)
    Steve,
    Things are looking great. Looks like you have a great bulider. Sure does keep the headaches to a minimum. I betcha you and the family can't wait. It won't be long now. Keep the pics coming. Good luck!!!
    Cypress, TX
    Quote Originally Posted by divnkd101 View Post
    Steve,
    Yea, the weather has been nice and everything is moving along nicely. I am real excited. Thanks!
  1. Deer in Scuba Steve's pool
    By DJK555 in forum Pools, Pets and Creepy Critters
    Last Post: 09-28-2010, 05:19 PM
  2. Welcome year 2007 agp newbies
    By hrsdennis in forum Above-Ground Pool Construction & Repair
    Last Post: 03-21-2007, 06:03 PM
  3. Steve's pool project 1-24-07
    By skamp in forum In-Ground Pool Construction and Repair
    Last Post: 02-20-2007, 01:30 PM
