I don't mind. Wow! Chock full of GREAT questions!Originally Posted by lauriefree
Actually, it doesn't encroach as much as you would think, but it's perceptive to pick up on it--I wish I had thought of it and I might have changed the design a little.As for the solar deck, since it is just about surrounded by fence, doesn't that kind of encroach on the sun the deck receives? I know there are legal and safety considerations regarding fencing. We do not have a deck at all, and I wonder how we could design one that wouldn't throw too much shade on the panels.
However, since my pool is basically an east/west alignment, the north run gets full sun most of the day--that's a 44' length. Most of the day the west end gets good light, too, but it's passing by mid afternoon. Around noon, the east end comes into its own, and later in the day the south run also steps up.
However, were I to do it again, I would extend the decking east and west to move the fence away and give me more space inside the fence--it wouldn't be solar panel, just decking. I intend, this year, next year or the year after () to extend the east end.
But despite that, here in North Central NJ, the water hit 96 degrees last summer and we usually are swimming by May 1 or the following weekend, and swim clear through Sept. If Sept is sunny we can go the whole month but it usually starts raining again. Still, I close around Oct 1. I do use a solar cover as well--I have a 16mil transparent that insulates really well.
As I said, I have divided the system in half: North West and South East so I can control them both, and when they are all full on, I get nearly double the flow. Also I have a couple of panels leaking and I'm waiting for IP to send me new ones. So rather than struggle to drain them, I'm only running the NW section which has no leaks. We've had cold nights into the low 40's and a lot of rain the last few days so the water is only 69-70--too cold!
Frankly, no. Rollable solar panels lying on the ground would be MUCH cheaper. The decking is the same surface area as 3 4'x20' panels. I have 30 2'x4' deck panels--even at the reduced rate of $50 per panel I have over $1500 in deck panels, plus hoses and clamps. It's comparable to a permanent roof-mount system, but not the rollables.Do you think the money you paid for a solar pool is comparable or better (less) than installing some solar panels separately?
But the benefits are: invisibility--no ugly panels to find space for or to mount. A COOL deck--all that water flowing keeps 'em cool--and my split system is cooler than stock. Easy to fix: I can replace most any panel but the ones where the stairs mount in 15-30 minutes, max.
But the main thing is my wife wouldn't tolerate most AG pools, nor solar panels all over. This pool works like an in-ground but gets taxed like an above ground.
Yes, the panels and the solar cover are it. I did have the electrician run 240v 40amp cable from the circuit box to the wall nearest the pool, so if I want to put in a heat pump I can. I won't do gas.Is the deck the only form of heat you use? It would be so great not to depend on anything else, but I'm probably a couple hundred miles north of you (in the Albany NY area.) I like warm water, hate polluting emissions and paying for fossil fuels.
In your area, summers are shorter (went to college at Binghamton, my brother went to Union, so I'm somewhat familiar with it.) Your heating problem will be in early June and after Labor day, not July and August.
I dealt with them by I'net and phone. Since they ARE expensive pools, plus my site prep was expensive (not to mention all the cedar I bought for the railing and gate), we figured it would be worth it to fly up there to see the pools first-hand. So one spring Sunday I flew to Buffalo, rented a car, and drove up to Grand Island. They gave me the grand tour and I ended up buying a pool--but not until AFTER I had my building plans approved by the town.Does Island pools have a local presence for you, or did you deal with them via the internet and phone? Will they recommend an installer in my area, do you think?
Finding a local installer may be a problem, but their contract installer is a lot closer to you than he is to me--he's between Syracuse and Buffalo. I suggest you talk to IP about pools they have sold in your area...they are better informed on that than I am.
It's really funny that I bought a pool designed and built in Grand Island, New York, located between Buffalo and Niagra Falls! That reminds me: Their climate is VERY similar to yours--I think that's why the solar pool was so popular up there.
But I think you are also asking if I would buy this pool again. Yes, I would--and knowing now what I know I would handle the plumbing differently, too.
Hope this helps.
