Thread: 2 jets not working
    Dec 2005
    Rancho Murieta, CA, USA.
    Default 2 jets not working
    Any thoughts why 2 of my 6 jets are not blowing any air? I am running a 2HP pump that is dedicated to the jets. No blower. 4 of my jets work great but 2 of them do not blow air.
    Looking at my constuction photos (below) I see the 2 jets that do not blow air (red arrows) elbow up from the main line, while the 4 jets (blue arrows) that do work all elbow down. Any thoughts? What can I do to fix this?
    Matt
    Owner/Builder, 28,000 Gallon IG swimming pool.
    Dec 2005
    Default Re: 2 jets not working
    opps the title should be jets not jest. Can a mod fix this for me?
    Matt
    drumr is offline ** No working email address ** Thread Analyst drumr 0
    Gordonsville, Tn.
    Looking at the plumbing, I'm wondering if its because the air line that feeds the 2 jets that don't have air coming out is lower than the air line around the rest of the spa. Maybe water is filling up the air line on those 2 jets and won't blow out.
    Is there any way you could hook a shop vac (in reverse where it is blowing) and feed it into the air line to blow any water out to see if that is what's causing the problem?
    Just a thought....
    JD
    Honesdale PA
    JD is onto something. Matt, I'm confused about the statement in your first post about 'No Blower'. I don't know anything about spas other than the basic principles and then that's very limited. Looking at the plumbing around the right side blue arrow it looks like there may be water and air lines joined. True? and if so which is which? Adding to what JD said you may try a wet-dry shop vac to suck any water out of those non-working jets and see if the system functions. Fire the pumps up, get the other jets working, then try sucking water from the non-working ones.
    Lightbulb Re: 2 jets not working
    Matt, I think the previous posters are on to something. What I suspect is that, because the airline to those 2 are below (further below ?) the water, the air you're forcing into the line is seeking it's 'path of least resistance' by only going through the top 4 jets. Without having to resort to the shopvac, you can try to plug the working lines (you may have to do one or two or perhaps all before the air forces the water out of the other two) - once the air has created a path to the last 2 lines, they should continue to bubble after unplugging the others. I'm speaking from lots of experience, though mine is from plugging multiple lines while closing a few hundred pools each fall. Please give this a try, if it doesn't work, try the shop-vac thing from above. (I realize that this is somewhat of a PITA, but it's just one of your spa's idiosynchrities and once you get used to having to plug the other lines before the other two kick on, you won't think twice about it) (BTW- you could probably just cap them with your palm).
    Dec 2005
    Thanks everyone for your comments. What you are saying makes sense and I will give it a try next time I heat up the spa.
    Matt
  1. DE out the jets...
    By Muggi in forum Pool Equipment & Operations
    Last Post: 05-11-2012, 12:56 PM
  2. Brass deck jets versus Jandy deck jets
    By pumpkineater59 in forum Pool Equipment & Operations
    Last Post: 04-12-2012, 11:58 PM
  3. two of my jets have come out how do i fix them
    By danhuff11 in forum General Interest
    Last Post: 07-07-2011, 07:27 PM
  4. Air/Bubbles from jets
    By LG1003 in forum Pool Equipment & Operations
    Last Post: 07-06-2007, 11:14 AM
  5. Jets not working
    By janmo in forum Pool Equipment & Operations
    Last Post: 07-03-2007, 03:31 PM
