Results 1 to 10 of 14
Thread: Pump Efficiency, Head, Flow, and related technical info
    mas985's Avatar
    Pleasanton, CA
    Default Re: Pump Efficiency, Head, Flow, and related technical info
    You did not mention your plumbing. What does the pool builder want to put in and what do you want? Lines sizes, number lines, returns, skimmers, main drains, etc. Also, how far from pool to pad.
    Your pool size is pretty close to mine and I have two skimmers, a split main drain and 4 returns.
    Ideally, I would have each skimmer and the main drain pair on a separate 2" lines all the way back to the pad. 3, 2" lines are equilvalent to a single 3" line plus it will allow you to turn on just one of the three to isolate a suction line for repair or to drain the pool via the main drain only.
    For the returns, you could go with one 2.5" line, two 2" lines or four 1.5" lines. Each configuration is equilvalent in terms of head loss. If the pad is close to the pool, you could go with 1, 2" or 2, 1.5" lines.
    This should give you pretty close balance between suction and return. Adding ball valves at the pad to control flow will allow you to fine tune your flow rates.
    Mark
    I have two skimmers and the main drain with 3 - 2" lines going back to the pad which is @ 25' from the pool. There is a single 2.5" return line. Each line has a neverlube valve on it at the pad
    There is no extra plumbing to divert the water to drain the pool via the main drain. Wouldn't there have to be a diversion valve to send the water somewhere other than back to the pool?
    mas985's Avatar
    Pleasanton, CA
    Quote Originally Posted by msm859 View Post
    Yes usually, a drain pipe is placed right after the pump with a manual valve so you can dump the water with either a hose or directly into a drain. You can also use flexible backwash hose to dump it on the lawn.
    Also, it sounds like your plumbing is fine and will give you decent flow rates.
    Mark
  1. Can someone help estimate my Total Resistance to Flow (Feet of Head)
    By 1PoolNoob in forum Pool Equipment & Operations
    Last Post: 06-09-2013, 12:17 PM
  2. Recommendations For Replacement Pump Or Pump Motor (1.5" Piping, High Head)
    By ChuckDavis in forum Pool Equipment & Operations
    Last Post: 05-25-2013, 03:56 PM
  3. Confusing info from Taylor Technical support
    By fishandfly in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-24-2008, 09:00 AM
  4. Pump Efficiency
    By chem geek in forum Pool Equipment & Operations
    Last Post: 01-22-2007, 12:59 PM
  5. Dynamic head, SWCG and 24/hr pump operation.
    By sailork in forum The China Shop
    Last Post: 07-11-2006, 02:44 PM
