Closed Thread
Results 1 to 10 of 22
Thread: Above Ground pool light
    Carterville,IL
    Default Re: Above Ground pool light
    hey thanks sevver..........the fountain now is a freebie when you order the light. I paid $99 for both plus shipping. I was concerned about the lighting, however now that I have been told by you and a friend that a 110 is ok.......we're good to go. I plan on putting in the return hole as stated, I don't think we'll need PVC do you? My friends have an esther w also, and the return hose fits right to the light?????
    Morris, IL
    The hose fit to the light, although it was a bit small for the hose for my tastes. It tightened down ok though and no leaks so far.
    Yes, 110V, I can run it with the pump off one GFCI no issues.
    The fitting is about 1/64th smaller than typical, I put a shutoff directly on it by scarring it up really good and using a ton of glue - no leaks 3 yrs later, so it must have worked well.
    I'm still looking into the LED version of it but it's expensive - if possible, I'd like to get that or retrofit my own - I've got a lot of experience with LED's, so setting that up should be relatively simple.
    Guess I'll just wait til the bulb blows, then i have a csing to play with....
    Carterville,IL
    Quote Originally Posted by matt4x4
    So matt........here's our wiring so far. Tomorrow they start to level for our ag at 8 am. We (HE) ran a gfci from the box indoors through a timer (intermatic) which is also right indoors by our box. That is it's very own circuit going to the pump. Then he ran another one that was not being used, but already hooked up to power out as well. He plans to bury them both together, one for the pump alone and the other one for the aqual.....and aux's off of that one. Is that ok......we wanted plug the aqual and pump into the same box and use the secondary for extra power for the "future" decking. What do you think..........so many say NO to plugging the light and pump together....it's a 1 1/2 HP Jacuzzi pump. Let me know. He will finish up the wiring tom. after they set up and leave and while in which time the water bill is accelerating??????????????? You probable can understand how handy it would be to use the pump plug in for the light too and use that other wire for extras???????However.....a thought on this issue??? the pump IS run through the timer and the aqua L would be too....however it DOES have a shut off button? This is nuts. The darn outdoor wire is NOW 125$ for 250 feet........Copper you know.
Closed Thread
  1. CFL Pool Light Conversion & can't seal American Products Pool Light
    By DrBAF in forum Pool Equipment & Operations
    Last Post: 09-11-2012, 11:09 PM
  2. Above ground pool light question
    By LedZepFan in forum Above-Ground Pool Construction & Repair
    Last Post: 06-14-2012, 10:04 PM
  3. In-ground Pool Light Won't Work or Turns Off Sporadically
    By moblaine in forum Pool Equipment & Operations
    Last Post: 07-29-2011, 11:46 PM
  4. pilot light won't light on pool heater
    By packerfan in forum Pool Equipment & Operations
    Last Post: 06-12-2010, 03:10 AM
  5. Pool Light Ground
    By TX78539 in forum Pool Equipment & Operations
    Last Post: 10-29-2007, 10:11 PM
