Results 1 to 10 of 14
Thread: pool assistance, part II
    North Florida
    Thumbs up Re: pool assistance, part II
    Of course, I wanted everything except the jump rock (no kids) for my pool, but money WAS a consideration .
    Really wished we would have added either a spillover spa or a heater, as I really missed getting into the pool when the weather turned cooler. But money WAS a consideration so we opted to have enough electrical brought out to the equipment pad to install a heater at some future date. For now, I have to wait until maybe sometime in March to get back in the pool .
    We did get a waterfall for pure aesthetics; it's centrally visible from several rooms in the house.
    We have a Polaris 280 (pressure side) which works great for us, despite the kinked hose that may have something to do with the cold weather. Just be sure your return connection is in an easily accessible place and NOT centered underneath your waterfall!!!
    Definitely worth the money to go a full 40' in length, which was about the most we could go on our lot, as that makes lap swimming do-able. I wish we had gone a bit deeper, maybe 7' or 8'. We contracted for 6' but the actual depth might be just a bit shy of that. It's still deep enough for me to tread water for water aerobics, but deeper would have allowed us to jump in and maybe not hit the bottom.
    The cozy corner/deep water swimout was worth it and gets used a lot.
    Salt water chlorinator is great and I don't regret getting it.
    The one thing we got that was an absolute must-have (for us) was PebbleSheen. We had to jump through a few hoops to get an applicator to come out our way, but it was so worth it in the end. If we had not already had gunite when we found out that Pebble might not be an option, we might have scrapped the pool entirely. I know you stated you're not a fan of Pebble, but you also wanted to know what we'd spend the money on and I'd definitely get Pebble (either Tec or Sheen) again.
    We will probably sell this house within the next 5 years, so we wanted the pool to have an impact over other pools in the area, if possible, for our budget. In our area, the waterfall, the overall pool size, and defintely the Pebble Sheen are visible features not found on other pools.
    Good luck.
    Sandy
    mas985's Avatar
    Pleasanton, CA
    Default Re: pool assistance, part II
    A couple of considerations.
    First a waterfall or spillover will not only increase evaporation but will also raise the PH in the pool. SWG pools also seem to raise PH so you will be using a considerable amount of acid when dealing with both. So if your water is expensive, as is mine, I would shy away from water features but it is a personal choice. I would go with the SWG since it really has a lot of advantages but not many disadvantages.
    Also, I have kids and the deep end with a jump board was a key buy for me. They are on it all the time and spend very little time in the shallow end.
    I went with plain white plaster since I wanted a light pool anyway and did not think the other materials were worth the cost for extra life. At the time is was twice the cost for twice the life and they will probably have better materials by the time I need to replace my plaster. I would stay away from colored plaster as that will molt and fade over time so if you really want color then it would be worth the cost to go with the higher end materials.
    Hot tub for me was worth it and the kids spend a lot of time in there when not on the jump board. It is especially nice in cooler temps since I can easily heat that without heating the entire pool.
    One thing I would really suggest is pay attention the pool plumbing. Most pool builders do not have a good handle on hydraulics. A couple of tips:
    It is nice to have separate suction lines with ball valves for each skimmer and the main drain all the way back to the pad so you can not only adjust the flows but also easily empty the pool when needed. I would suggest at least 2" lines if they are separate and 2 1/2" if combined.
    It is not necessary on the return lines to be separate but again it is nice to have to be able to adjust the flows. One thing that separate lines does provide is low head loss. This is important to keep the flow at maximum and run time at a minimum.
    If go with a spa, I would suggest either a 2 speed pump or a 3/4 HP circulation pump combined with a higer HP pump for the spa jets. Do let the builder talk you into single speed 2 HP pump for both the spa and the pool as this will cost you big bucks in electricity.
    In generally, I always believe that both energy and water effiiciency should be top considerations when building a pool. Costs will only go up in the future.
    Mark
    Jul 2006
    I can not thank you enough for your replies.
    there are indeed so many considerations, it is quite overwhelming. I really appreciate the third party opinions.....
    Jul 2006
    Quote Originally Posted by dawndenise View Post
    Good luck.
    Thanks - I am not against the pebble coating, I just do not know much about it, and it sounds really expensive.
    Jul 2006
    OK, regarding the jump rock on the deep end - about $350 down here in Dallas. A diving board is about the same, but I would get my homeowners insurance canceled. the rick is not considered a diving board...go figure.
    Regarding the spa - hot-tub.....how many jets ?
    No Need is offline Registered+ Thread Analyst No Need 0
    San Dimas, Ca
    My spa is 8' it has 8 seats and 2 have stacked jets.
    Jul 2006
    Pearland, TX (Houston suburb)
    PJ,
    Looks like you have asked some really good questions. Decisions, decisions, decisions. Welcome to the hardest part of a pool build. You mentioned that you think you found a good pool builder. Can I suggest that you go and take a look at some of his/her work. Specify some of the things in a pool you would like to see to help you make your decisions.... i.e. pebble tec finish, plaster, spa dimensions, number of jets, cleaning units, etc. That will also give you an idea of what the workmanship of the builder will be. Ask the pool owners as many questions as possible... How satisfied with builder? How long did the build take? If you could change anything, what would it be?
    As for my system:
    22 x 36 with 9' wide tanning ledge (21k gallons) Deep End = 6.5'
    Plaster
    SWG system
    8' spa with 8 jets (2.1/2" piping)
    Polaris 280
    Cool Deck Finish
    Good Luck
    Jul 2006
    anyone do pebble tec and wish they didn't?
    or wish they would have spent the extra for it?
    San Dimas, Ca
    My Brother has Pebble Tech, his Family doesn't like it, too rough. He says if they stay in the pool too long, the Kids get scrapes from the Pebble Tech surface.
  1. Algae and cloudy pool..Someone pleeease help me!!! I NEED ASSISTANCE!
    By smoovie in forum Dealing with Algae & Slime
    Last Post: 05-27-2013, 08:28 PM
  2. Pool Liner Assistance?
    By zooba72 in forum In-Ground Pool Construction and Repair
    Last Post: 05-10-2012, 09:25 PM
  3. Purchasing Home with Vinyl Pool, Need Assistance
    By falker in forum In-Ground Pool Construction and Repair
    Last Post: 05-09-2011, 12:38 PM
  4. New to the forum and in need of assistance
    By tideman in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 04-21-2011, 04:34 PM
  5. new pool to be - assistance please!
    By shrike in forum In-Ground Pool Construction and Repair
    Last Post: 12-25-2006, 03:30 PM
