.3 FC
7.6
80 TA
liner pool indoors
in use 8 months+
Further down the SWG path..... can someone help me understand / explain,
that if I connect the metal stainless parts in the liner pool "they are basically floating on the liner now not touching the outside of the pool.....to an earth ground" , will there be a reduction in rust from the SWG environment on the stainless screws and other stainless steel parts ? Will I create any new problems?
Does connecting the SS parts to ground stop metal rusting?
The only negative I have with SWG is the SS rust, I replaced screws but still have more than I want of rust.
If I can not stop the rust, next if I go back to bleach and an ORB "or some controlled chlorination" control I might probably have none of the rust issues.
Searching for a solution. Anyone knowledgeable about rust conditions and stopping them.
Thanks in advance.
deep_blue
