You can measure your CYA level with a CYA drops test, available in many test kits. CYA tests can also be ordered separately, if a kit does not provide for CYA testing.
While I and many on these forums have utilized and been very happy with "Ben's kit", aka the test kit from Pool Solutions, it appears to be unavailable at this time. This thread:
http://www.poolforum.com/pf2/showthread.php?t=6326
will list some alternatives, including some with good clearance prices. Although Wal-Mart carries an HTH 6-way kit that is often written about here as an alternative, I wouldn't recommend it for you as it has only 2 tests for CYA, does not measure free chlorine, and only measures total chlorine up to 5.0.
Finally, yes, you'll just be dumping straight bleach into the pool - in the deep end in front of a return with the pump running. You use the Bleach Calculator to determine how much to put in, depending on how much you want to increase your chlorine level.
