To figure out what level of chlorine will kill your green/yellow algae, which may be mustard algae if it looks like powder, we need to know your CYA level. Also, if your SWG manufacturer recommended a high CYA level of 70-80 (which most do to ensure high efficiency of the SWG), then the minimum FC you should be maintaining is 3.0 ppm, not the 1-3 that they recommend. Even 3.0 is on the low side, but most people with an SWG seem to do OK with that, though a few battle mustard algae and need to set a higher setting of around 5-6 ppm.
So, first test your CYA level and also see if you can figure out of you have regular green algae, which will be free floating, or if you have mustard algae, which is yellow/brown and looks like dust. The amount of chlorine you will need to maintain until all the algae is killed is as follows, depending on the CYA level.
On this forum, the traditional chart to look at is at this post and you can certainly start by trying shock levels per that chart. If you find that the algae is not going away, then you can use the following chart instead which uses more recent information and understanding, but is less tested.
As you can see, it takes quite a high Free Chlorine (FC) level to kill mustard (and also probably Black) algae, but the actual "active" chlorine concentrations are only 0.3 ppm for Green and 1.0 ppm for Mustard/Black algae. The high CYA levels cut down the effective "active" chlorine level. If you add some acid to get your initial pH lower (to around 7.2) then you may be able to use lower chlorine levels than shown in the above table since the large amounts of chlorine will raise the pH and lower chlorine's effectiveness.Code:CYA Green Mustard & Black 30 12.5 21.5 50 20.0 34.0 75 30.0 50.0
Once you establish a high chlorine level, you then need to maintain it until all the algae is gone (which will require lots of filtering, so keep your pump running 24/7) and until the chlorine doesn't drop significantly overnight (initially it will drop as it kills and oxidizes the algae so you'll keep adding chlorine until that stops). The most important ingredient is patience. Then, when you are done, keep your FC level at least at 3.0 ppm, especially if your CYA level is high.
Good luck and keep us posted as to your progress.
Richard
