Results 1 to 10 of 57
Thread: Downsides to salt pools
    Default Re: Downsides to salt pools
    Quote Originally Posted by Waterworks View Post
    I brought one of his ladders back to my shop so I could try to do some kind of test on it. I was thinking of setting up 2 buckets, one with high chlorine and one with high salt and setting each leg of the ladder (because they are evenly corroded at this point) in it's own bucket. I would take pictures before and after and compare the effects. I would also test the water every day or two and keep it balanced. I wish I had a way to test a third part so I could do high chlorine with CYA. Does anyone think this test would be worthwhile, and does anyone have any tips to make the test better?
    If anyone can tell me how to post a picture, I will post a couple pics of the ladder.
    Brad, I think that this forum is now limiting uploading of pictures, but if you send them to me (via E-mail -- click on my name on any post and there will be a link to E-mail to me) then I can host them on the website I use for the other pool stuff I have and then your post can link to that.
    Sorry to hear about this customer, but man, that much chlorine with no CYA is horribly corrosive. As for what test to do vis-a-vis salt, part of what you want to compare is moderate chlorine levels (say, 5 ppm FC with no CYA) with salt at 3000 ppm vs. the same chlorine levels with salt at around 300 ppm. We already know and understand the effects of CYA on chlorine so that isn't as useful. What we really want to know is whether the salt in the presence of chlorine accelerates the corrosion so you want the same chlorine level in both buckets with the only difference between the two being the salt level. To make this a reasonably fair test, go ahead and add baking soda to raise the TA and maybe even some calcium chloride for CH. That would make it very much like pool water (so try and keep the pH around 7.5 as well). Whenever you test or add chemicals, be sure and do the same sort of mixing (circulation) in the two buckets as that also affects corrosion (if there is no circulation, then the buildup of "rust" products probably slows down additional corrosion).
    This story really emphasizes the need for customer education about SWG and especially about testing your water regularly. I can hear Carl's words now...
    Stay ahead of your water!
    Take 2 to 5 minutes every day for pool maintenance!
    Richard
    I thought of another possible reason why SWG manufacturers recommend high levels of CYA (typically 70-80 with 80 "best"). In this thread (starting at around post #30) I said that the reason for high CYA in SWG pools is that this is more efficient at producing chlorine. Though this appears to be true (based on pool owner's experiences with runtime), I didn't say what happens when there is a buildup of chlorine at the plate. In addition to production of chlorine, there is also a competing reaction of producing oxygen. If the reaction producing chlorine slows down, then the reaction rate of producing oxygen can speed up in its place, though the production of oxygen is normally less favored than that of chlorine (technically, the production of oxygen is more likely to occur in an equilibrium sense, but it has a much higher activation energy than the production of chlorine so results in an overvoltage such that chlorine is more favored than oxygen).
    It is interesting to note that different SWG systems use a different voltage to drive their cells. Some operate in the range of 6-9 volts, but others are in the range of 22-30 volts. Though the voltage level required to only produce chlorine and not oxygen is quite low (perhaps between 1.16V and 1.45V at normal pool concentrations of pH and chlorine), higher voltages will probably produce both chlorine and oxygen with chlorine being produced more. I do not know if higher voltages change this relationship, but suspect that it might, with the oxygen proportion increasing somewhat at higher voltages (though still produced in lower quantity than chlorine). At any rate, having lower CYA levels may very well increase the oxygen proportion and this can be dangerous since the other plate is producing hydrogen. Though hydrogen by itself is not explosive and in water does essentially nothing, the combination of oxygen and hydrogen can be dangerous if this combination of gasses were to accumulate (if the pump shuts off but the SWG cell keeps running, for example).
    The blog link at the first post in this thread has been reporting some explosions of SWG systems and I wonder if those pools were using lower CYA levels than recommended and produced more oxygen that could have been at explosive levels with hydrogen. It is also possible that the explosions weren't actual ignitions of hydrogen and oxygen, but high pressure bursts from the buildup of gas pressure. It should be understood that under normal operating conditions when the SWG only operates when the pump is running, that the risk of explosion is virtually nil. I'm just trying to sort out some unusual circumstances (where the salt cell didn't shut off when the water flow stopped) to better understand what is going on.
    [EDIT] A further note: Even the most dangerous levels of hydrogen gas and oxygen gas in a 2:1 ratio will not spontaneously explode unless the pressures are very high (much higher than what pipes would handle, so bursting would occur before explosion) or the temperatures are very high (at least 400C) so generally some sort of spark or flame is required to trigger a literal thermal explosion. In other words, the risk of oxygen production and explosion is low; the risk of a pressure burst is high if the salt cell operates in a closed valve environment (which would only occur if some component failed to operate properly). [END-EDIT]
    Richard
    giroup01 is offline Registered+ Thread Analyst giroup01 0
    Canada
    Richard,
    Can you expand a bit on the chemistry behind low CYA levels favoring O2 production ?
    Thanks,
    Reseller of Taylor water-testing products for Canada
    Quote Originally Posted by giroup01 View Post
    Sure.
    First let's take a look at the only reaction that appears to be reasonably possible at the cathode (the negatively charged plate). The other reactions that can occur at this plate include the plating of metals (iron, copper) that are in the water. Also, the [EDIT] high (sorry about saying "low" at first -- I was "thinking" the right thing but "wrote" the wrong word) [END-EDIT] pH in the region of this plate make scaling of calcium carbonate much more likely.
    2H+ + 2e- --> H2(g) ...................... Eo = 0V
    In other words, this is the generation of hydrogen gas. It can also be written as coming from water to produce hydroxyl ion:
    2H2O + 2e- --> H2(g) + 2OH- .......... Eo = -0.8277V
    The different Eo readings reflect the fact that Eo is defined to be at standard conditions which means that each of the species dissolved in water have a concentration of 1 mole/liter and each gaseous component has a partial pressure of 1 atmosphere.
    Now let's look at the two different competing reactions that appear to be reasonably possible at the anode (the positively charged plate):
    2H2O --> O2(g) + 4H+ + 4e- ........... Eo = -1.229V
    2Cl- --> Cl2(g) + 2e- ....................... Eo = -1.35827V
    Cl2(g) + H2O --> HOCl + H+ + Cl-
    Cl- + H2O --> HOCl + H+ + 2e- ......... Eo = -1.482V
    The first reaction is where oxygen is produced from water. The other reactions are the production of chlorine where I show the additional reaction of chlorine dissolving in water to produce hypochlorous acid. You can see that the Eo value is more negative after chlorine gas dissolves in water to make hypochlorous acid and that would seem to imply that the reaction is not favored, but again this is only because the Eo is defined for standard conditions (which are theoretical and may not always be actually achievable) of 1 atmosphere pressure of chlorine gas with 1 mole/liter concentration of hypochlorous acid AND 1 mole/liter concentration of hydrogen ion (i.e. a pH of 0), AND 1 mole/liter concentration of chloride ion.
    For the cathode, I listed the reduction potentials as oxidation potentials (i.e. with negative numbers) to indicate that a voltage needs to be applied to make the reaction occur. Note that it takes a lower (absolute) voltage to produce oxygen than chlorine. This represents a difference of about 25 kilojoule per mole in favor of oxygen formation over chlorine formation. HOWEVER, chemical reactions have what is known as an activation energy which is an energy barrier that must be overcome before the reaction can happen. In electrochemistry, this barrier is called overvoltage which represents the additional electrical potential needed to get an electrochemical reaction started. Oxygen has a very high overvoltage of 700 mV while chlorine has an overvoltage of only 50 mV.
    So if we add the overvoltages to the standard potentials, we see that to produce oxygen it takes 1.229+0.7 = 1.929V while to produce chlorine it takes 1.35827+0.05 = 1.40827V. Or we can look at producing hypochlorous acid directly as 1.482+0.05 = 1.532V. Now these voltages do not account for the actual concentrations of the various species in pool water as I noted above.
    If we want to really know about the true voltages required and which reactions are favored, we need to convert from standard conditions to actual concentrations. There is a formula for doing that called the Nernst equation as follows:
    E = Eo - RT/nF * ln(K)
    where "K" is the ratio of product concentrations (raised to powers corresponding to their stoichiometric quantity in the formula) to reactant concentrations. "R" is the gas constant, "T" is the temperature in Kelvin, "n" is the number of electrons in the equation and "F" is the Faraday constant. Sometimes this Nernst equation is written with a "+" and the "K" value is inverted to have reactants divided by products.
    Anyway, if I assume reasonable initial conditions of a pH of 7.5 to get [H+] = 3.7x10^(-8), normal dissolved oxygen levels (based on 21% oxygen in the air and using Henry's Law) to get [O2] = 2.6x10^(-4) moles/liter and converting to 0.0065 atmospheres (partial pressure), using normal chlorine levels of 3 ppm with 30 ppm CYA to have [HOCl] = 5.8x10^(-7) moles/liter and chloride concentration of 3000 ppm to have [Cl-] = 0.052 then this adjusts the oxygen equation by (0.02585/4)*ln(0.0065*(3.7x10^(-8))^4) = -0.47V so E = -0.75V for oxygen. The chlorine equation is adjusted by (0.02585/2)*ln(5.8x10^(-7) * 3.7x10^(-8) / 0.052) = -0.37V so E = -1.11V for chlorine. I'm not certain on the handling of the oxygen quantity in terms of molarity vs. partial pressure, (I believe I did it correctly) but it turns out it doesn't matter much in this case so let's keep going.
    Applying the overvoltages again gives is E = -1.45V for oxygen while we get E = -1.16V for chlorine. So at least initially, the production of chlorine is favored over the production of oxygen and if the voltage applied to the salt cell is set to be BETWEEN 1.16V and 1.45V, then only chlorine can be generated and oxygen cannot. [EDIT] I neglected to do the concentration adjustment calculation for the cathode for the production of hydrogen, but that would modify the overall voltage by the same amount regardless of whether oxygen or chlorine were produced at the anode so it's not that relevant to this discussion. [END-EDIT]
    If higher voltages are used, then both chlorine and oxygen will be produced with chlorine favored over oxygen. If you have ever done the "home" experiment of taking two carbon cores from D-cell batteries and connecting them to a 6V transformer (as I have), then putting this into salt water produces both chlorine and oxygen (you can smell the chlorine and you can "pop" the gasses with a flame where the oxygen and hydrogen combine) and can somewhat vary the ratio of the two depending on the salt concentration. If you use sodium bicarbonate as the electrolyte, then you get only hydrogen and oxygen and not chlorine.
    The salt cells appear to use voltages that are much higher than these minimum amounts that would ensure that only chlorine gets generated. I'm sure that this is partly due to the rather low chloride concentration in pool water (especially today, since early salt generators wanted 6000 ppm instead of 3000 ppm). Otherwise, you would need very large generating plates to get decent generation rates. So with voltages of 6-9 volts for some manufacturers and 22-30 volts for others, it would seem that both chlorine and oxygen could get produced. My guess is that the higher voltage units have a greater tendency to produce more oxygen proportionately than the lower voltage units, but that's just a guess.
    Now what I do not know is whether the materials (coatings) used for the generating plates in a salt cell are designed to somehow inhibit the oxygen generation, but I suspect that is not the case. (If anyone knows about this, please let us know).
    As the electrolysis proceeds, the product concentrations build up at the generating plates (though there is water flow to help keep them lower) and this slows down the generating reactions. Note that the reaction with oxygen produces hydrogen ion so is acidic and that the production of chlorine AND dissolving of that chlorine in water also produces hydrogen ion so is also acidic. However, the oxygen reaction produces one hydrogen for each electron while the chlorine reaction produces half a hydrogen for each electron. This means that as the pH gets lowered near the plate, the chlorine reaction will become more favored, assuming that the chlorine gas is able to dissolve in water rapidly. Having CYA in the water helps make this happen because it combines with the hypochlorous acid that is produced so that the reaction of chlorine dissolving in water can continue at a rapid pace. So the lower buildup of products in the chlorine reaction, due to CYA binding with the generated hypochlorous acid, means that this reaction becomes even more favored compared to the oxygen generation.
    This can be netted out as follows:
    HOCl + CYA --> Cl-CYA + H2O
    Cl- + CYA --> Cl-CYA + H+ + 2e-
    Each succeeding reaction above moves the products into another form and that takes them away from being able to go "backwards" to create reactants again (or to inhibit or slow down the creation of more products). It is almost as if one turned up the water flow with respect to sweeping away chlorine gas, but that this is done chemically.
    Richard
    Canada
    Sure.
    Thanks! ...I'll have to chew on that, but yes, thank you!
    When you say:
    Would this explain why SWG manufacturers seem to specify a somewhat higher than normal CYA? To increase the ratio of chlorine to oxygen?
    Smile Re: High Recommended CYA Levels
    Richard, your explanations of SWG chemistry are truly awesome, but I don't believe for NY second that the reason for the manufacturers' 70-80ppm CYA recommendation (I've actually seen 80-100ppm recommended) has anything to do with real-world chemistry. Rather, I suspect it has more to do with a slightly different interpretation of the acronym "CYA", rooted in the early days of the SWG evolution when reliable operation was not up to par with current devices. In a loss-of-power event, for example, high CYA levels would help to ensure that all your residual FC doesn't disappear on a sunny day before you've noticed something is amiss. I believe there is no longer any rationale justification for this recommendation other than my suspicion that the manufacturers have no interest in pursuing the matter and are content to leave it unchanged.
    Personally, I barely manage to keep my CYA level above 25ppm, and have experienced no consequences from that during the four seasons I have operated my Pool Pilot SWG -- although I do test my FC and Ph quite often.
    Gunslinger,
    You may be right, but users of this forum, including Evan (waterbear) noticed that the output efficiency of the salt cell fell dramatically at lower CYA levels. That is, you needed to increase the time and/or power of the salt cell to achieve the same FC level when the CYA was below the 70-80 recommended range and this effect was MUCH larger than the sunlight protection effect of the additional CYA (which is quite minimal at higher CYA -- see this graph) . Now this specific CYA level probably varies by manufacturer, but this effect is absolutely real as it was reported by multiple users. Maybe your salt cell is one of the lucky ones that operates well at lower CYA, or maybe you never got to the 80 ppm CYA where the efficiency dramatically improves for some salt cells.
    So at least some SWG manufacturers may be recommending higher CYA in order to have higher efficiency. The issue then becomes whether efficiency of chlorine generation is the only factor or whether the proportion of oxygen generation is also affected. I don't know the answer to that and was just speculating based on chemistry -- we don't have real-world data on SWG output (i.e. measuring the gasses) to know for certain.
    giroup01,
    I believe the high CYA recommendation is primarily for SWG cell efficiency as mentioned above. I do not know if the oxygen effect is real (there might be coatings on the plates to inhibit oxygen generation, if that's even possible) or if the manufacturers know about it if it is or if they recommend higher CYA partly for that reason. Basically, I don't know a lot. But if the chlorine generation rate goes down at lower CYA but the conductivity stays the same and there is the alternate reaction of generating oxygen available, then it seems reasonable to assume that more oxygen is generated at lower CYA. The extreme example of this occurs if you remove all of the chloride and just have a different electrolyte (sulfates, carbonates, etc.) in which case you get pretty much ONLY oxygen and hydrogen. I had fun as a kid making such concoctions and carefully exploding them (this is definitely a "don't try this at home" scenario where you must not use glassware and should wear glasses).
    Richard
    Waterworks is offline In the pool biz Thread Analyst Waterworks 0
    I was just speaking with my customer that has the indoor Stainless Steel pool. (This is not the same pool that I spoke of last week with the massively rusted ladders and +100 ppm chlorine.) Once his pool was up and running with the SWG he quickly noticed corrosion issues with the walls and floor of the pool. He is now using pucks, and I had him add a little bit of extra CYA. The build up of CYA over time won't be an issue because he drains the pool periodically. He has not noticed any corrosion since getting rid of the SWG and switching to pucks.
    I told him that I thought that high chlorine was the cause of the corrosion and that I thought that by adding some CYA and more closely monitoring chlorine levels we could avoid the corrosion while allowing him to use his SWG again. The pool is completely 316L grade Stainless and is grounded properly. When the initial corrosion happened he brought a metallurgist out to look at the problems. The metallurgist told him that 316L stainless could not handle sodium chloride in concentrations above 500 ppm. This is vastly different from everything I've read about 316L steel.
    Let me know what you think.
    Brad
    Brad,
    I can only refer you to this same EPA document that I referenced before where it says that the 316 stainless steel is more resistant to chlorine pitting than 304. However, it does show in at least some studies that 316 is superior to 316L, but I would find it surprising that salt levels above 500 ppm are simply corrosive to 316L. The chlorine appears to be far more corrosive to stainless steel than the salt level, though the salt level may accelerate such corrosion. So my take would be that using CYA would cut down the corrosion from chlorine to the point where the higher salt levels of an SWG pool wouldn't be a problem with 316 type steel.
    However, this is all just speculation on my part based on the fact that we haven't had any reports of stainless steel corrosion in SWG pools that have been using CYA (and haven't had horribly high chlorine levels). We did have the one report of the indoor pool with 3-5 ppm FC, but that had no CYA.
    So if your customer is up to it, they can bring up the CYA level in their pool to at least the 10-20 ppm range (if not 30 ppm) and then try the SWG (with the 3000 ppm salt). My prediction is that they won't see corrosion. If they had 304 stainless steel, then they *might* see corrosion eventually, but even then I'd bet it would take a few years.
    Now having CYA in an indoor pool is going to present a different set of problems since indoor pools tend to get combined chlorines that do not break down as readily as outdoor pools (due to the lack of sunlight) so you might need to periodically use a non-chlorine shock (potassium monopersulfate) for the indoor pool. First try monitoring (or have the customer monitor) the combined chlorine level -- if it's not a problem, then you're done. If not, then use the non-chlorine shock.
    By the way, you mentioned that the customer saw corrosion issues with the walls and floor of the pool. What does that mean? Isn't the pool plaster/gunite? Is he now talking about corrosion as in roughness of the plaster finish? Or is this pool made out of stainless steel?! Or do the walls have some stainless steel bars and by "the floor" he means metal floor drains? I'm confused.
    That's my two cents (again, for what it's worth),
    Richard
    The pool is a one-piece shell made entirely of 316L stainless steel and was set in place by a crane; like a one-piece fiberglass pool, but made of steel. Don't ask how much it cost because I have no idea. I won't be able to convince him to try the SWG on that pool again because if I'm wrong it's an awfully expensive mistake. After the first round of corrosion the metalurgist applied some sort of clear corrosion proof sealant and somehow got rid of the original corrosion. I'm guessing that this was expensive as well.
    Brad
  1. What PPM Sodium for non SWG pools when adding salt?
    By mjs31 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 08-24-2007, 03:37 PM
  2. CYA for Salt Chlorinator Pools II
    By Karin in forum The China Shop
    Last Post: 02-07-2007, 12:47 PM
  3. SALT POOLS feedback please
    By Poolsean in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 01-29-2007, 04:14 PM
  4. CYA for Salt Chlorinator Pools...
    By Karin in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-22-2006, 08:13 PM
  5. The negatives side of salt pools
    By estermer in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 04-23-2006, 10:38 PM
