Thread: Dimming a Pool Light
    Scottsdale, Arizona
    Default Dimming a Pool Light
    I'd like to have my pool light on a dimmer switch. I believe it's a 500w bulb so getting a dimmer that will handle the load should not be a problem but are there other issues that could prevent me from doing this ? Will it shorten the life span of the bulb ? Is there a specific type of dimmer i need to use other than the standard weather proof type unit ?
    Honesdale PA
    Default Re: Dimming a Pool Light
    Nothing special. Standard dimmer. Running a lamp at lower than specified voltage will increase the life of the lamp as the filament is not running as hot. Another thing that kills incandescant lamps is the inrush current when first turned on. This is when most blow. Filament is cold, resistance is low, starting current is very high and the weakest part of the filament bears the brunt and poof. So, if you ramp up the voltage at turn on, or just leave the control off maximum, you should get a lot of extended life.
    Scottsdale, Arizona
    Nice ... and I thought it was a lame idea..
    My pool is set up so the light faces my party area.. I need to tame it down a bit.
    Honesdale PA
    I have 3 floodlights on the roof of the poolhouse and got a lot of complaints because of the glare and high intensity. So I got 90' of white ropelights and strung them along the top of the poolfence and put those on a dimmer. Lot nicer. Floods are there in case the area has to become daylight real fast, such as seeing the bottom of the pool.
    Central Texas
    Quote Originally Posted by Phillbo View Post
    Same here. I bought one of those blue plastic lenses to cover my light and it does a good job of taming it down. The only problem is that the lense isn't a good fit on the light and it falls off easily.
    Tom Wood
    15K IG Plaster, Sand Filter, Polaris 180
  1. CFL Pool Light Conversion & can't seal American Products Pool Light
    By DrBAF in forum Pool Equipment & Operations
    Last Post: 09-11-2012, 11:09 PM
  2. pilot light won't light on pool heater
    By packerfan in forum Pool Equipment & Operations
    Last Post: 06-12-2010, 03:10 AM
  3. Pool Light
    By GA Mark in forum Above-Ground Pool Construction & Repair
    Last Post: 09-16-2006, 07:31 AM
  4. New Pool Light
    By Tredge in forum In-Ground Pool Construction and Repair
    Last Post: 09-05-2006, 10:37 PM
  5. Pool light out
    By KirstenHW in forum Pool Equipment & Operations
    Last Post: 06-22-2006, 03:48 PM
