Results 11 to 15 of 15
Thread: SALT POOLS feedback please
    Scottsdale, Arizona
    Default Re: SALT POOLS feedback please
    What type of pool finish do you have?
    Inground Plaster
    How old is your system?
    9 months
    What Salt level do you maintain?
    3200 PPM
    What are the benefits you're experienced from switching to salt?
    lower maintenance ( just add acid every other week). Love the soft water feel and no need to wash chlorine off after a long swim.
    What are the problems you've experienced since switching to salt?
    None
    How often do you have to clean your cell from calcium scale?
    I check it every 3 months or so but have yet to need to clean it
    How often do you test your water?
    Weekly in the summer, Monthly in the winter
    tonyl is offline Registered+ Thread Analyst tonyl 0
    Indiana
    Vinyl Inground
    Four years. Pool is open 6 months a year.
    3300-3400
    Ease of maintenance. Consistant chlorine supply. Much easier on the skin, especially noted by my kids with skin dryness prior to switching.
    None.
    Never, but I check it every 3 months. It's always been scale free.
    Weekly during the swim season
    Sean,
    As you know from other posts on this forum, many (but not all) SWG users experience rising pH which requires regular additions of acid to maintain pH (and possibly adding baking soda to maintain TA over a longer period of time). Non-SWG users using BBB or liquid chlorine do not generally see the pH rise unless they have high TA, low pH, aeration from water features, or a new plaster pool (that is curing). waterbear (Evan) has found that using 50 ppm Borates significantly reduced this acid demand, possibly by reducing chlorine demand and allowing for lower power levels or run times of SWG generation.
    Richard
    Sean,
    Richard is correct. Since adding the 50 ppm sodium tetraborate my acid use has decreased from about 24 oz every 2-3 week to about 6 oz evey 5 weeks and my pH tends to stay right around 7.6. I have also found that by lowering my adjusted TA to about 70 ppm has been beneficial. Since I have done that I have not seen my pH rise above about 7.9 while before it was not uncommen for it to read 8.2. I have also seen a huge decrease in chlorine demand since I can now run my cell at between 4-10% output depending on temperature (Goldline Aqualogic PS-8) to maintain my FC of 4-5 ppm while before I added the tetraborates I ran the cell at 15-25%! Also, my pool gets constant aeration from the spillover spa and water features (deck jets and spillover pots). I maintain my CYA at about 70 ppm and am located (as you know) in N. FL.
    Evan
    SF Bay Area, CA
    in-ground concrete with fiberglass finish
    about 8 months
    about 3000-3200 ppm
    I fired the pool $ervice! (Easy to maintain)
    My new solar landscape lights are badly corroded from my pool sweep's splashing around. I need to find cheap plastic replacements.
    Hmmm.... gotta see if my husband has been doing this...!
    Cl & pH weekly; the rest every 4-6 weeks
    about 27,000 gal IG w/spa
    Polaris cleaner
    Autopilot SWCG
    Pentair cartridge filter
    Smile Re: SALT POOLS feedback please
    Vinyl In-ground, Vinyl Above Ground, Inground Plaster, exposed aggregate, tile.
    >>4 yrs
    >>3200ppm minimum
    >>Better "feel" to the water.
    >>No more burning eyes underwater.
    >>Noticeable increase in bouyancy.
    >>No more lugging bleach home from Wal-Mart!
    >>Absolutely NONE.
    >>Generally once mid-season.
    >>Twice a season to re-calibrate salinity (using a Taylor test kit).
    >>At least once a week for FC and Ph.
    >>Maybe twice a season for everything else.
    This is the absolute best piece of equipment I ever bought --with my Polaris 280 cleaner just one step below!
  1. Salt generation systems .........feedback please
    By sae99 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 10-23-2013, 03:45 PM
  2. Downsides to salt pools
    By chem geek in forum The China Shop
    Last Post: 09-12-2007, 04:18 PM
  3. CYA for Salt Chlorinator Pools II
    By Karin in forum The China Shop
    Last Post: 02-07-2007, 12:47 PM
  4. CYA for Salt Chlorinator Pools...
    By Karin in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-22-2006, 08:13 PM
  5. Salt water ok for Rock Pools ?
    By JohnInSoCal in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-07-2006, 08:42 PM
