Thread: What first... 1st Test
    Stafford, Virginia, US.
    Default What first... 1st Test
    Hey... Appreciate any suggestions on what I should do first...Then 2nd, etc... What should I add?
    28,500 16X40 Vinyl IG Pool
    Water Temp: 80
    SWG - Autopilot
    FC 3
    CC .5
    TC 3.5
    PH 7.2
    ALK 70
    Cal 60
    CYA ZERO
    Thanks for your support!!!
    Scott
    Default Re: What first... 1st Test
    Quote Originally Posted by The Pool Newbie
    Water Temp: 80
    SWG - Autopilot
    FC 3
    CC .5
    TC 3.5
    PH 7.2
    ALK 70
    Cal 60
    CYA ZERO
    Scott
    What is your salt reading, btw?
    First thing to do is to bring your FC level up to 10 ppm to get rid of the CC, Easiest way is with bleach (sorry, at work now on a Mac and don't have access to bleachcalc to figure out how much to add)
    Second thing to do is get some stabilizer (CYA) in the water to bring it up to (and here is where the great debate can start) somewhere between 30-80 ppm. It seems that most SWG manufacturers recommend 60-80 ppm and many of the people on this board that might or might not use them like to stay between 30-50 ppm. I personally keep my CYA between 60-80 ppm and my FC (from a SWG) at around 3 ppm and I have had no problems.
    Third thing is to maybe bring your TA up just a bit with baking soda....maybe around 100-120
    Your pH will creep up with the use of the SWG...nature of the beast! Just keep an eye on it and when it gets to about 7.8 use muriatic acid to bring it back down.
    Happy swimming!
    Thanks for the info! I take it I can only get stabalizer from a pool store... Is it Cyanuric Acid? Salt is about 2900PPM I think last I checked...
    Scott
    You can also find CYA at Walmart, Home Depot, Lowes, etc. in the pool dept. Shop for price! It is all the same stuff!
    Don't know for sure on the autopilot (Poolsean could answer it better than me) but I THINK the recommended level for salt is 3200 ppm. Might want to check in your manual.
  1. pool test strips vs dropper test kit
    By sputterbug10 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-22-2012, 11:23 PM
  2. CYA level-my test and pool store test
    By hancop in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 09-20-2006, 07:13 PM
  3. Test results vary between meter and drop test - not sure what to do?
    By west1745 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-29-2006, 04:27 PM
  4. Necessity for ordering Salt Test in PS234 test kit
    By Scarlett in forum DPD-FAS based testing
    Last Post: 06-13-2006, 01:04 AM
  5. PS233 test kit and CYA test question
    By mshumack in forum DPD-FAS based testing
    Last Post: 06-06-2006, 11:28 PM
