Results 1 to 8 of 8
Thread: Rough Plaster Solutions
    Default Rough Plaster Solutions
    We have a 16,000 gal, saltwater pool. It was finished in Sept. 2004. We have the 3M Colorquartz in our plaster. The last four months or so we have noticed that the flat surfaces (seats, steps) are getting very rough to the point of us not wanting to even use the spa (too cold for the pool right now). I did a search here and saw that others have had this problem but did not see what the ultimate solutions were. Can anyone offer some advice? I tried using the metal tile brush on it but no luck with that. We tested today, here are our numbers:
    FC-6
    CC-0
    TC-6
    pH-8.2
    Alk-180
    Cal-380
    Cya-30
    Temp-60
    Default Re: Rough Plaster Solutions
    Oops, forgot to put the salt level. 3200
    GutierrezPlastering Guest
    hey what state are u located in?
    We are in CA
    mas985's Avatar
    Pleasanton, CA
    Quote Originally Posted by AprilRose View Post
    FC-6
    CC-0
    TC-6
    pH-8.2
    Alk-180
    Cal-380
    Cya-30
    Temp-60
    At first glance, it looks like your Ph & Alk are too high and with a CH of 380, it is likely that you are having some scaling conditions. Also, with a PH of 8.2, your SWG is unlikely to work very well. So the first order of business is to drop your PH down to 7.2 - 7.4. This should drop your alk some as well but you may need to work on that too with aeration and acid.
    As for making the surface smooth again, that may require an acid wash. I would check with your plaster installer to see if they have any suggestions.
    Mark
    Well, here we are months later. We are pretty sure that it is scaling and we decided to have the plaster sanded. There were places that were kind of rough even before the scale so I was looking forward to having nice, smooth plaster. We went round and round with California Pools, the builder. They wouldn't even come out to look at it. Then they gave us the number of the plaster company to contact directly. I called them at least a month ago and they said they would call us. NOT! So I got the name of a company to do the sanding and clean our tile off the Internet. They were supposed to come tomorrow and I just got a call. They need to delay it a couple of weeks. Long story short, can anyone recommend a company to do the sanding here in Inland Empire, CA that is reliable? I hate doing business with someone without any kind of recommendation. Thanks.
    the woodlands, texas.
    Quote Originally Posted by mas985 View Post
    I disagree. Sanding is your best bet.
    See ya,
    Kelly
    dhale1 is offline ** No working email address ** dhale1 0
    Elkridge, MD
    Kelly-- what are your thoughts about jacks magic the blue stuff for removing scaling???
    Thanks.
  1. New Plaster is rough? What to do
    By Dakota in forum In-Ground Pool Construction and Repair
    Last Post: 06-19-2012, 11:00 PM
  2. Rough Plaster
    By Ozzzz in forum In-Ground Pool Construction and Repair
    Last Post: 08-19-2007, 10:54 AM
  3. Rough Plaster Solutions-Happy Ending
    By AprilRose in forum In-Ground Pool Construction and Repair
    Last Post: 04-17-2007, 09:55 PM
  4. rough plaster
    By HAYMAN in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-19-2006, 06:47 PM
  5. Question about rough plaster
    By Lenny in forum In-Ground Pool Construction and Repair
    Last Post: 03-28-2006, 09:36 AM
