Results 1 to 8 of 8
Thread: Color change?
    SeanB. is offline --General User-- Weir Watcher SeanB. 0
    Missouri City, Texas
    Default Color change?
    Well the contractor who did our pool start up finally showed today to add in the salt and start our SWCG this morning. The water was a nice clear blue yesterday and is now cloudy and slightly green this afternoon.
    Is this typical with the first addition of salt?
    Site owner -- www.troublefreepool.com
    Indiana.
    Default Re: Color change?
    I would be checking the chlorine to make sure you aren't in the middle of an algae bloom. If the SWCG was just started, you very well may be. If he shocked it, it may indicate you have a metal problem with your water.
    Quote Originally Posted by JohnT View Post
    The SWCG shows it to be in the good range. I've got it circulating. I'm hoping it will start to clear up by tomorrow.
    Indiana.
    Quote Originally Posted by SeanB. View Post
    I don't believe the Intellichlor displays chlorine level, only what it is generating. If it is algae, you need to be much higher than the generator can make except when set to superchlorinate. You need a test kit to really know what the situation is in your pool.
    It is the salt level. The "good" range just means that there is adequate salt and that it is producing chlorine. I want to give it a chance to do it's job. I just wondered if the actual addition of the salt could be responsible for the color change - it was a pretty rapid change, faster than I would anticipate for a simple algae bloom.
    Scottsdale, Arizona
    I saw no color change when I added the salt to my pool...
    14'x31' kidney 21K gal IG plaster pool; SWCG (Saline Generating System's SGS Breeze); Pentair FNS Plus 48 DE DE filter; Whisperflow 1 HP pump; 8 hours hrs; kit purchased from Ben; utility water; summer: none; winter: none; PF:5.7
    Central Florida
    We had no color change either last week when our SWG was finally started. At 100% output for 24-hours, our SWG got the chlorine level well above 3.0 in our 10,000 gallon FG pool, but not nearly high enough to shock to clear an algae bloom.
    Pool has cleared up. I used the swcg to shock to 24 hours and then had all chemicals checked - low on cya and calcium, high on pH.
    Corrected levels and pool is blue and gettting clearer daily.
  1. new water...overnight color change
    By PFPAM in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-26-2007, 12:41 PM
  2. Determining color change for TA
    By MrSparkle in forum DPD-FAS based testing
    Last Post: 07-15-2006, 08:29 PM
  3. 2 Jandy Color Pool Lights/1 Color Spa Light not synced
    By dc in forum Pool Equipment & Operations
    Last Post: 07-01-2006, 05:36 PM
  4. 2 Jandy Color Pool Lights/1 Color Spa Light
    By dc in forum In-Ground Pool Construction and Repair
    Last Post: 06-29-2006, 12:19 AM
  5. Odd Color Change when Testing for Chlorine
    By RudyandRocky in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-19-2006, 07:04 PM
