Thread: Recommended resurfacers in AZ?
    Default Recommended resurfacers in AZ?
    I have a pool that's about 26 years old now. The plaster is pitted algae heaven right now.
    I'm seriously considering trying an Ultraguard application, but my wife doesn't like the idea and thinks I should find a good contractor. I don't know that I have the money for that, but does anyone have any recommendations in the Phoenix area for either a replaster or a Pebbletec finish (or other variants)?
    Thanks in advance!
    ehorn is offline Registered+ Thread Analyst ehorn 0
    Tucson, AZ, USA.
    Default Re: Recommended resurfacers in AZ?
    I don't have any experience with people who will replaster but you can go on Pebbletec's website and find licensed installers, not just pool builders. I did a quick search and found quite a few you could call. Just go to:
    http://www.pebbletec.com/locate_installer.aspx
    Also I saw a website of someone in Glendale, Phoenix area which looked impressive:
    http://www.pradoandsons.com/
    Check it out, can't hurt to get a free estimate.
    Jul 2006
    I just had mine done in Gilbert, AZ and I am happy. After interviewing 5 companies, I went with Perez Pool Plastering in Phoenix. The did everything they said they would and always on time. I had Ultrapoz (similar to 3M quartz), new tile and over 1000 sq ft of cooldeck (acrylic lace). With the spa, and it was about $8k.
    The only disappointment is that he put a bunch of pucks in the pool for the startup, which I pulled out today, but I will start another thread for that.
    The company is very reputable and the guy has been in the Phoenix area for over 20 years.
    Scottsdale, Arizona
    Quote Originally Posted by azhobbs View Post
    how big is your pool and was the 1000 sq ft of slab already exisiting ?
  1. clarifer, recommended or not?
    By pbotz2000 in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-19-2012, 09:56 AM
  2. Recommended cleaning robots?
    By bellbound in forum Pool Cleaning: Manual or Automatic
    Last Post: 04-24-2012, 12:38 PM
  3. Why is dichlor not recommended?
    By Farmingtonpool in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 03-23-2012, 03:05 PM
  4. what is the recommended setting when vacuming???
    By traceyb in forum Above-Ground Pool Construction & Repair
    Last Post: 05-25-2007, 10:54 AM
  5. Recommended contractors in Bay Area?
    By 105ex in forum In-Ground Pool Construction and Repair
    Last Post: 04-24-2006, 12:57 AM
