Results 11 to 14 of 14
Thread: Too much salt?
    Default Re: Too much salt? Results from the Taylor kit
    Well, I received my Taylor kit yesterday and took a salt reading.
    It came out to 4400. I remember the person that came out called in to the shop before adding the salt and I overheard him saying that there already was "salt" in the pool (he did a test) and how much should he add. They told him to add all 10, but he told me he stopped at 9 and I could add that one if necessary later.
    So, I suppose my pool is somewhat smaller than 20K gallons but I don't know how much salt was in there from the city water and it being balanced.
    with a salt level of 4400, should I just let it go through the winter and see if some gets washed out or should I try to correct it now? Who knows, maybe I will have to drain the pool during the downpore or 2 we usually get in January (I was promised an overflow, but they did not install one, but that is another story ).
    Chris
    Socal_biker Guest
    Well for 18 yrs I thought my pool was ~18K gallons.
    Only this year did I measured the volume of water going in when I filled it last. It was actually ~15K.
    Poughquag, New York, USA.
    Not sure where you live. Here in the northeast, we will probably get between 15 and 20" of precip between now and opening in the spring, so if it was me, I would leave it!
    North Florida
    My own pool of about 17K gallons is running with 3800-3900 PPM salt right now. It had been up to 4100 after I had a run-in with mustard/yellow algae and had to do mega-chlorinations with bleach, which added to my salt level.
    Time, splashouts from my waterfall and a "rain drain" have all combined to reduce my salt level. As long as my system is not flashing "high salt" at me, I'm just leaving it alone.
    For my own pool, my initial level of salt in the pool came from the bleach I had been using to manually chlorinate the pool prior to the SWCG becoming operational. I tested my city water and it did not register any salt on my test (PS 234S).
    Sandy
  1. Salt water system faulting high salt.
    By Skelly607 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-27-2013, 10:43 AM
  2. Aqua Rite low salt reading when salt has been tested high
    By DirtRider67 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 08-19-2011, 05:58 PM
  3. Salt Level Keeps High without Addition of Any Salt
    By TooSalty in forum The China Shop
    Last Post: 08-13-2011, 01:56 PM
  4. Salt in a Non-Salt Water pool
    By wollypog6 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-31-2006, 10:01 AM
