Central Fla.
I want to build a spa next to my small 16,000 Gal in-ground screened in pool.
The bottom of the Spa will be above the pool deck.
Is there a heater that will do both my pool and Spa?
Would I need to get 2 heaters?
Could I set up the heater plumbing so it heats the spa and the water over flows into the pool thus heating the pool too slowly, and the fresh water is drawn from the pool?
Either way i do want my spa to draw water from the pool using 1 Pump for both the pool and spa.
What I want to be able to do.
1) heat just the spa.
2) heat the spa and pool
3) heat just the pool
What would I need to make this work and what are some different ways that I could approach this?
This should also make it easier to keep the spa water balenced?
