Carl, I will have easy access to the pump. If I stay with one pump, if I want to turn on the spa or water features (pump on high) will I still be using the SWG and filtering the water at the same time? Is it just a matter of how the valves are configured/plumbed?
Hope that wasn't a dumb question but still a little ignorant how that all comes together![]()
Think I will buy the sub panel and do that myself. Spa has 6 - 1 1/2" Theraputic Hydrobody jets plus a 1 1/2" center fountain. They heat form PVC so as not to have too many 90's. Each jet outlet is homerun. Doing the calcs, I came up with 25 gpm for a 6 hour turnover based on size. For filtration only, a 2 HP is, IMO, way overkill. It would turn over in less than 2 hours and I don't think that's enough time per day to have a pump run. PB doesn't think it's an issue.
