Closed Thread
Thread: separate pump & filter?
    Default separate pump & filter?
    First year winter prep for me, I have the pool part done but not sure on the pump. Do most seperate the union between the pump and filter or just store it all together? I read the sticky on this above but both do it different, just wondered what everyone does.
    AG, DE filter
    Thanks-
    Meade
    fcfrey is offline ** No working email address ** Thread Analyst fcfrey 0
    Central PA USA
    Default Re: seperate pump & filter?
    For 3 years I never took the pump and filter in ---- Just drained and pulled the plugs and that was it ------ Last year I read a piece on Hayward's website saying that the pump should be stored inside because the area near the seal has a small chamber which can not be drained easily. That may explain why I had to replace the seal the spring after year 3. I installed a waterproof plug and socket on the pump's electrical and now bring it in every year.
    Your question about breaking things apart at the unions ---- Unless you have a very tight configuration and things are small -- you probably will find it easier to take things apart. Unions tend to swivel anyhow so it will misalign everything anyhow.
    Save yourself some aggravation and take it apart --- Also go to HD or Lowes and get a little container of plumbers silicon grease to lube the O-rings when you put things back together. It helps the seals in the valves also.
    Good luck.
    Honesdale PA
    Don't know about that small chamber but never had a problem leaving my superpump out all Winter. I do use a shop vac to suck the thing dry and then put probably a pint of RV antifreeze in it. Never replaced the seal and the pump has been in since 97. For the sand filter I just drain it.
    Default Re: separate pump & filter?
    If you have a DE filter or cart filter and it's all attached to one base, then it's just easier to drain it and move it inside. If you have a sand filter, unless you plan on removing the sand (not recommended) it's better to seperate the pump and move it inside, while draining the filter.
    I don't have a common base for my pump and filter so it is easy to disconnect the pump for storage. I did have to lube the insides of the 6-way valve last season. That's an easy job.
    Every union I open, I pull out the O-ring, dry it and lube it (teflon lube) and put it in a MARKED zip-lock bag, squeezing the air out of it. This keeps them soft and flexible year to year.
Closed Thread
  1. Is it possible to run Intex SWCG pump and filter unit with pump disabled?
    By jtran69 in forum Intex-type Pool Setup & Operations
    Last Post: 08-19-2012, 09:15 AM
  2. Separate pump for heater?
    By DrMacZed in forum Intex-type Pool Setup & Operations
    Last Post: 07-27-2012, 01:01 PM
  3. Cost of separate color for Pebble Tec with Tanning Ledge and Beach Entry
    By jeremywitte in forum In-Ground Pool Construction and Repair
    Last Post: 05-25-2012, 05:07 PM
  4. Does Muriatic Acid and Water Separate
    By smallpooldad in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-03-2008, 01:08 AM
  5. Possible to separate pipe from valve body??
    By cruzmisl in forum In-Ground Pool Construction and Repair
    Last Post: 05-21-2007, 07:24 PM
