Results 1 to 10 of 46
Thread: AL's Pool Project 10-17-06
    SeanB. is offline --General User-- Weir Watcher SeanB. 0
    Missouri City, Texas
    Default Re: AL's Pool Project 10-17-06
    Wow, looks great! You've obviously put A LOT of thought into the aesthetics of your entire project. Can't wait to see the finished product.
    Site owner -- www.troublefreepool.com
    No Need is offline Registered+ Thread Analyst No Need 0
    San Dimas, Ca
    The stone work is finally done. Calling in for pre plaster inspection for Tuesday. Here is the latest.
    ehorn is offline Registered+ Thread Analyst ehorn 0
    Tucson, AZ, USA.
    Looking good there. I like the stone work, I'm sure you are eagerly looking forward to finishing the pool. Good luck with the pre plaster inspection!
    San Dimas, Ca
    Quote Originally Posted by SeanB. View Post
    Me too....
    San Dimas, Ca
    I'll have water in my Pool today!
    Tucson, AZ, USA.
    Hey thats looking good, what kind of finish are you getting on the pool?
    If you want to know how much water your pool holds be sure to check your water meter before and after you fill the pool. Would love to see pictures of the pool filling up.
    Eric
    San Dimas, Ca
    Eric, it's a 3m finish. We doubled the amount of the of the 3m product.
    I'm hoping for a real deep blue color.
    San Dimas, Ca
    The pool is only half full had to slow down the fill. This morning noticed a chip in the plaster right in the middle of the first step, needless to say I'm not real happy about this.
    I check out the rest of the pool and found a nice 2 inch long gouge on the side right next to the bottom step.
    I called my plaster company this morning, and he is sending out a guy to fix it today! This is the way customer service should be.
    AL
    Hey, you may want to turn the water back on at a very low flow rate. If you leave it off, you may end up with a permanent water line since it is still curing. As long as the level is rising, even if VERY slow, you should be OK.
  1. New Member Starting Pool Project
    By Lburg in forum Above-Ground Pool Construction & Repair
    Last Post: 11-06-2012, 10:06 AM
  2. Pool project
    By Smokey in forum --cleanup--
    Last Post: 10-02-2012, 01:04 PM
  3. Subcontracting your own pool project?
    By minddeal in forum In-Ground Pool Construction and Repair
    Last Post: 02-28-2007, 10:15 PM
  4. Steve's pool project 1-24-07
    By skamp in forum In-Ground Pool Construction and Repair
    Last Post: 02-20-2007, 02:30 PM
  5. That massive pool restoration project
    By peppercorn in forum In-Ground Pool Construction and Repair
    Last Post: 01-04-2007, 10:10 PM
