Yeah, nothing like black goo under red fingernails.![]()
I tried the Drain king and isolated the drain and the skimmer at different times. Each seemed to have a good flow coming back. The drain is hard to tell because..well, I'm not getting in there to check. But....I put leaves over the drain to see if they floated away from the force of the water and they did...and the drain seems to suck just as it did before.
That drain king thing shoots a skinny stream of water..pulsating yes, but by the time it makes all those corners how forceful do you think it is?
If there was a clog, wouldn't I have the same results if the basket was in or out? Not priming?
The basket is free of any debris, I was concerned that there could be hair that I couldn't see. Some roofing pebbles but I removed them. Same thing.
There was a little debris in the impeller (try gettin' to that without ruining your manicure!)-removed that and still not priming.
Kurt..yep. Cleaned and Lubed the O ring. Even the O ring on the drain plug.
The woman at the poolstore (I know, I know) said that it was probably from the broken basket. She didn't come up with that on her own though AND she didn't have a replacement basket.
I'm concerned that the pump is failing and isn't strong enough to pull the water through the basket.
Hopefully I'll find a new basket today.
Will post the follow up for sure. Thanks for the replies.
