Thread: pump will only prime when basket is out
    Scottsdale Arizona
    Default pump will only prime when basket is out
    moved to other thread
    West Palm Beach, FL
    Default Re: pump will only prime when basket is out
    Did this problem just start recently or has this been happening for awhile? If so how long?
    Scottsdale Arizona
    probably just within the last couple of weeks. I have the pump on a timer so it comes on when I'm not watching it. I didn't know it wasn't priming fully because I wasn't standing over the skimmer basket.
    Now, I'll know better to check on it every once in a while. Even when I clean out the basket, I clean it and then let the pump come on and prime itself.
    It's frustrating to watch that basket get alllllmost full and then have a darned bubble at the top.
    It's like feeling like you have to sneeze and then you don't!
    Also..there's no water spurting from the lid....
  1. Cleaning pump basket
    By Jacob99 in forum Pool Equipment & Operations
    Last Post: 05-15-2012, 01:09 AM
  2. Pump basket lid stuck
    By cmcq in forum Pool Equipment & Operations
    Last Post: 10-02-2010, 08:25 PM
  3. pump will only prime when basket it out
    By ScottsdaleSwim in forum In-Ground Pool Construction and Repair
    Last Post: 10-23-2006, 10:52 PM
  4. Pump problems... Hard to prime and air in the pump lines
    By tinyprotagonist in forum Pool Equipment & Operations
    Last Post: 06-29-2006, 11:38 PM
  5. How often should you clean your pump basket?
    By Beachnut_PA in forum Pool Equipment & Operations
    Last Post: 06-26-2006, 12:20 PM
