I was hoping to close my own pool and the one thing I can't figure out is where to connect the air compressor in order to blow out the lines. From what I can see, I only have two openings where it can be connected (see picture). The PVC connections are all glued everywhere else. So do I connect to A (opening to filter basket) or B (opening to backwash hose), or none of the above? I also assume that I should change the filter to "winterize" when blowing out the lines. Please confirm. Thank you.
!!!!!!!!), a 'bounce/ ballance' line (an open pipe into the bottom of the skimmer that will "supposedly" keep the skimmer from drawing air if the water level gets too low vs. the skimmer opening) or a reserve line that is plumbed in at the time of construction to allow a 'quick and easy' skimmer line replacement in the event that the main line breaks (it's plumbed up near the main, ie working, line, but not plumbed into the pump unless the primary line fails). I'll assume that the pool builder didn't use the port for any of these, so glued the plug in, often from the bottom.
