Thread: testing for bromine
    Default testing for bromine
    I have the ps233 test kit and use this to test CL in my pool. Is there any way to test bromine levels using this same kit? If the answer is no is there a kit you can recommend?
    Default Re: testing for bromine
    test your chlorine and multilply the results by 2.25 and you will get the equivalent ppm bromine reading. If you want a bromine specific kit I highly recommend the Taylor 2106 which is their FAS-DPD kit for bromine. It will test all paramters that you need in a bromine pool.
  1. Bromine pool - no detectable bromine.
    By ptrdvs44 in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-17-2012, 05:58 PM
  2. Anyone else have a bromine pool
    By swreeder in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-24-2007, 12:45 AM
  3. Bromine testing (Waterbear?)
    By Pool in Carolina Blue in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-13-2007, 03:55 PM
  4. Bromine question
    By CanuckPool in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-16-2006, 10:02 AM
  5. Bromine to Chlorine
    By jrv331 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-30-2006, 09:26 PM
