Thread: Heater Question
Threaded View
    CanuckPool is offline *Removed User* Weir Watcher CanuckPool 0
    Jul 2006
    Default Heater Question
    I have a Pentair Mini Max 300 Nt heater.. only 4 months old. About 4-5 weeks ago I turned it on for 5-6 hours to heat up the pool, we went out came back and I noticed that the pool temp had not moved and that the heater was not on.. it was in the on position but it was very cold to the touch. I turned the thermostat to full and it still didnt come on. So I decided to take off the front panel, as I did so, it came on... interesting. Anyways fast forward a few weeks now, the pool temp is 60 and we havnt swam for about 2 weeks and obivously havnt been using the heater. I decided to do some vacumning and cleaning and decided to turn the heater on to test it. Well... nothing nada doesnt come on no matter what I try. I was doing a little reading and it appears there are about a dozen safety switches that could have tripped. water pressure/gas pressure ignition etc etc.
    On a side note, I mentioned on the forum a while back that my Jandy deck jets have developped a pulse to their squirt that wasnt there before. Could it be I have a blockage somewhere that is affecting the heater too? Everything else seems fine, i have 17 lbs on my sand filter which is about normal.
    oh, and more of a trivial question... apart from the gas line to the heater, there is no other "wires" or "power" that goes there. How does it get the power to run the electronic ignition and thermostat etcetc.
  1. heater question
    By poolhelp101 in forum Pool Equipment & Operations
    Last Post: 05-30-2013, 03:28 PM
  2. Heater question
    By Pamsel in forum Pool Equipment & Operations
    Last Post: 06-08-2007, 10:49 AM
  3. pool heater question
    By boomer99 in forum Pool Equipment & Operations
    Last Post: 05-14-2007, 10:07 PM
  4. Heater Question
    By halefmly in forum Pool Equipment & Operations
    Last Post: 11-26-2006, 03:46 PM
  5. heater question- what's your take?
    By tenax in forum Pool Equipment & Operations
    Last Post: 08-19-2006, 10:13 AM
