Results 1 to 4 of 4
Thread: 40% Polyquat
    jonv112 is offline ** No working email address ** jonv112 0
    Toronto, Canada
    Default 40% Polyquat
    I was just wondering as I have a bottle of algaecide that I used this year with the ingredients listing 40% poly [oxyethylene (dimethyliminio) ethylene (dimethyliminio) ethylene dichloride] and 60% inert ingredients. Has anybody else used this concentration of Polyquat before? I know that Wal-Mart used to sell Super-Algae Kill 40% by HTH. I still have 400mL left of the stuff. Will it do until I get some 60% next year?
    Smile Re: 40% Polyquat
    Jon, I've posted before that it's the same active ingredient that's in 'poly 60', just more watered down. As the chemical is the same, it will do the same job, but you need to use more to do the same job (provide the same protection). In fact, you have to use 1.5 qts to do what 1 qt of 'poly 60' would do. As you have a supply of the 40%, use it (x 1.5) to do the same thing as the 60%
    California
    Default Re: 40% Polyquat
    Yes, it should work fine, though you will need to use more of it by weight (or volume) than you would of PolyQuat 60%. The only problem with what you have is economics. However, if the price was less than 2/3rds the price of PolyQuat 60%, then you found something economical and the only problem is what exactly the "inert" ingredients are that you are also adding to your pool.
    [EDIT] Whoops! waste wrote his post at the same time I was. Sorry for the duplicated info. [END-EDIT]
    Richard
    Last edited by chem geek; 10-02-2006 at 08:05 PM. Reason: Noticed waste wrote the same info.
    Toronto, Canada
    Thanks for the quick reply. I got it at a closeout before somewhere. Now I'm trying to work out wether 1.5L of 40% or 1L of 60% will be cheaper. At my local pool store 1L of 60% is $29.95 CA. Is this price reasonable?
  1. Where to Buy PolyQuat 60?
    By b2001 in forum Dealing with Algae & Slime
    Last Post: 06-13-2010, 10:28 AM
  2. polyquat
    By hannadock in forum Pool Chemicals & Pool Water Problems
    Last Post: 09-11-2008, 12:53 PM
  3. How to use Polyquat
    By CTIGuy in forum Dealing with Algae & Slime
    Last Post: 09-08-2007, 02:28 PM
  4. PolyQuat??
    By Sam_I_am in forum Dealing with Algae & Slime
    Last Post: 07-29-2007, 10:45 PM
  5. polyquat
    By mikemedic in forum Dealing with Algae & Slime
    Last Post: 05-26-2006, 09:40 AM
