Results 1 to 9 of 9
Thread: Cell cleaning schedule.
    Scottsdale, Arizona
    Default Cell cleaning schedule.
    My Ecomatic manual recommends monthly cleaning of the cell with a muratic acid solution. I've been running the system for 2 months now and each time I have pulled the cell for cleaning I have not seen any scailing or build up of any kind. Could it be that the reverse polarity thing really does a good job of preventing build up or should I dip it in the solution anyway each month.
    My thought process is that the soultion will deteriate the cell a bit as well so if I don't see any build up then there is no need to clean... Anyone else have a cell that does not need cleaning very often ?
    tonyl is offline Registered+ Thread Analyst tonyl 0
    Indiana
    Default Re: Cell cleaning schedule.
    I've never cleaned mine and it's several years old (AquaRite). Reverse polarity cleaning works for me. No point in cleaning it when it's already clean.
    Hope this helps, Tony
    Scottsdale, Arizona
    Alright .. I've just heard so many stories from SWCG owners about cells goign bad because they did not clean them often enough etc....
    I guess the chemical balance of my pool along with the reverse polarity working as advertised may just add to the care free pool enviroment I've worked for
    Cool Re: Cell cleaning schedule.
    Philbo, if you are worried about the 'muriatic acid cleaning', do it as per schedual. Keep a bucket of the acid/ water mix to do it in (you can use the same solution for multiple cleanings). If you don't mind doing the process every month and it's not a big hastle, go ahead and set your mind at ease.
    Scottsdale, Arizona
    It's not a mind at ease thing ... No reason to dip it if it does not need it .
    Quote Originally Posted by Phillbo View Post
    Unless the guys who wrote the instructions on how much you should dilute the acid for an acid wash were idiots, they should have the solution diluted enough (but not too much) so that it will readily dissolve calcium carbonate scale while having virtually no effect on the titanium (or titanium coated with various substances) blades.
    As an aside, the calcium carbonate scale builds up on the blade that is highly basic, namely the blade that is producing hydrogen gas from the following reaction:
    2H2O + 2e- --> H2(g) + 2OH-
    It is the high alkalinity of this reaction that causes the calcium carbonate in the water to precipitate out of solution and onto the plate (shouldn't happen in a vinyl pool since you don't need much calcium in the water in that situation). The reversal of polarity moves the problem to the other plate while causing the following acidic reactions to occur at the original (now reversed in polarity) plate:
    2Cl- --> Cl2(g) + 2e-
    Cl2(g) + H2O --> HOCl + H+ + Cl-
    Cl- + H2O --> HOCl + H+ + 2e-
    Under these acidic conditions, any scale buildup should dissolve. So the secret is switching back and forth between the plates fast enough to prevent scale but not so fast as to degrade the electrochemical reaction efficiency.
    The only reason for the periodic dipping in acid is that this polarity reversal is not perfect and some scale could potentially build up in spite of the best efforts. All it would take is for the calcium carbonate to adhere just a little more than it dissolves when reversed and you could get a net buildup. Technically, you can see that the basic process is more strongly basic (alkaline) than the acidic process because HOCl is a weak acid so the formation of scale could conceivably occur faster than the dissolving of scale. Also, additional substances (such as metals) could conceivably be changed from a dissolved ion into a solid metal at the plate and will need to be dissolved by acid though a good design of the voltages used in the cell can minimize this effect.
    Richard
    Scottsdale, Arizona
    why does my head hurt everytime Richard replies to one of my post
    so, dip it when I see build up. otherwise leave it alone.
    I learned that Richard is a PIMP of the POOLS, and that is why I feel like a slut that cannot understand my pimp
    Yes I am a newbie
    Grecian 17'x33' Vinyl liner pool
    ZeoBrite filteration
    SWG Aqua-rite
    Sta-Rite Dura-Glas 1.5hp pump.
    SAM Light
    21037.5 gallons
    Houston.
    Does anyone have a picture of the build up on the cell? Mine 9 months old and the clean line has come on a couple times. I've cleaned it each time, but am not sure if it had anything on it or not. Where do you see the build up?
    Thanks,
    Robert
    22K gallon, IG, gunite, Sunstone Pearl White Pearl plaster, Aqualogic SWCG, Hayward Tristar pool pump, Pentair Whisperflo waterfall pump, Pentair Clean & Clear 320 cartridge filter, Sta-Rite heater.
  1. AutoPilot Dig 220 Low Amps-Cell?/Check Clean Cell
    By tthurman in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-01-2014, 07:41 PM
  2. New T-CELL-15 reading lower salt than 7 year old cell
    By sharknj in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-01-2013, 09:00 AM
  3. Salt Cell Cleaning
    By Phillbo in forum Pool Equipment & Operations
    Last Post: 07-17-2012, 04:44 PM
  4. SW cell needs daily cleaning
    By poolaris in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-23-2006, 06:57 PM
