Results 1 to 10 of 21
Thread: Skimmer plug got sucked through and is stuck
    Scottsdale Arizona
    Default Re: Skimmer plug got sucked through and is stuck
    I talked to a guy today that says he uses a drain king that attaches to a garden hose to create pressure in the line. I guess he gets golf balls stuck in his skimmer line often. No skimmer basket? No idea...Not really sure that will be enough but that will be the first go. Then we'll try the rope method.
    doggie- I thought about calling a "professional". I have to at least try first...
    It's hard to know if the "professional" will even know what he/she is talking about. If I had a referral then I would consider it a little more but I have little faith in the pool company's in my area.
    I'll keep you posted for sure.
    I have a ton of other questions about the equipment for her pool.
    Scottsdale Arizona
    So- we tried the drain king last night. Didn't work. I think because the plug isn't completely plugging the pipe..it lets too much water by to build up pressure. Even putting a tennis ball over the suction hole doesn't create enough pressure.
    We're hesitant to use the rope method now because we don't want to turn the pump on. The pressure from the pump might pull the plug closer to the pump or wedge it even tighter.
    A thin coat hanger type wire won't even pass the plug because we can't see into the stinkin' pipe.
    We dug to the line where it 90's to go to the pump last night. Today we'll cut it just before the 90 so we can have a straight shot at it. We'll use something rigid to cram into the pipe like 1" pvc.
    We'll lubricate the pipe from the skimmer hole to the plug.
    Any ideas on a type of lubricant? Something heavy that will sink and then I'll use a plugged piece of hose to push it to the plug.
    My friend that's helping is a pipe fitter so he's doing everything he can without cutting the kook deck...
    because that's gonna be a mess.
    The good thing is- Once we get it out, we're already down to the spa and pop up jet pipes that don't work so if there's something stuck in a couple of them we can fix it while we're in there.
    Scottsdale Arizona
    while attempting to push a wire line and pvc to the skimmer in an effort to free the plug we found that we were hitting something hard where we thought the plug was. I think it must have been a "T" or something. maybe where it "T"s to the drain. Who the hell knows.
    Anyway, we knew it wasn't rubber. SO we had already cut the line and thought perhaps the plug was between the cut and the pump. We stuck fish tap (heavy wire) in the pipe and attempted to guide it towards the pump.
    It only went a few inches. We quickly cut another section and found the plug.
    TOTAL LUCK. Because when your skimmer sucks something in..how the heck are you supposed to know where it is in the line?? Luckily it was where we were able to dig and super close to the first cut. I can't imagine it being wedged in the pipe under the cool deck.
    I swear I will never use one of those compression plugs again. The wingnut was plastic btw and I think it failed.
    Thanks for all of the ideas!
    Carl D- you were so right, Cut it out! We're just lucky enough that we didn't have to cut the deck.
    Now on to the other problems...
  1. Rubber plug dropped into skimmer line
    By brielly in forum Pool Equipment & Operations
    Last Post: 05-14-2012, 07:48 PM
  2. skimmer basket getting stuck?????
    By traceyb in forum Above-Ground Pool Construction & Repair
    Last Post: 07-15-2007, 06:32 PM
  3. Need to plug return and skimmer for repairs
    By jstonemo in forum Above-Ground Pool Construction & Repair
    Last Post: 05-13-2007, 09:33 PM
  4. Skimmer plug?
    By Davenj in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 08-31-2006, 12:32 PM
  5. Do I need to remove the plug from the skimmer?
    By ValAZ in forum Pool Equipment & Operations
    Last Post: 04-01-2006, 11:58 PM
