Results 1 to 9 of 9
Thread: Pump Problem
    Central Florida
    Question Pump Problem
    I have a Pentair WhisperFlo 1 1/2 HP Model : WF-6 Pump.
    I noticed today when my pump turns on it spits
    water out between the strainer basket and the motor
    (where it bolts together). I thought I was seeing
    things so I turned off the pump and then turn it back
    on and sure enough it did it again. I also did notice
    a some air bubbles through the clear lid when it
    turned on. After a few seconds the air bubbles went
    away. Has anyone herd of this ?
    Also I have some hairline cracks on the cantilever at
    every area where there is an expansion joint on the
    deck. Is this normal? I just don't want the cracks to
    get larger.
    John
    Jul 2006
    Default Re: Pump Problem
    Could it be the pump has losts its prime and takes a few seconds to suck the water back in. I think its normal to have a few bubbles on startup and then they eventually work their way out, especially if your pump is re-priming itself. Does your pump loose prime when you just shut it off or are you taking the pump basket out to clean.
    Guelph, ON, Canada.
    Sometimes when I turn on the pump for an instant, I get a bit of water splashing out between the clear cover and the pump casing. I've never been concerned as I figured it was the acceleration of water hitting the cover going from 0 to high lifted the cover slightly beyond the O-Ring compression. Once the pressure in the cover was maintained (acceleration of water =0), the O-Rings did their job. You may be getting the same thing at a different joint.
    With respect to the bubbles, assuming your plumbing is on deck (above the waterline), the water in the plumbing wants to flow back to the pool by gravity. This creates a siphon type suction in the plumbing for as long as the pump is off.
    If you have a small leak anywhere in the plumbing, and air can get sucked in and settle in the trap of the pump. If a lot of air gets in (either a combination of a larger leak, or long time between the pump running) the pump may loose its prime, and take a minute or so pull the water up enough to re-prime itself.
    You said it only takes a couple seconds to get rid of the bubbles, I think this is fairly normal, if it gets to the point the pump has to re-prime itself, you probably should tighten up all the plumbing fittings with Teflon tape.
    I don't quite understand your statement about hairline cracks.
    Carl Schnurr
    96,000 litre inground, vinyl liner, 1 HP 1speed pump, sand filter, SWG, installed 2005.
    Central Florida
    Thank you for the quick reply. My pump loose some prime when you just shut it off then turn it on. I figure some bubbles are normal. My main concern is the water that spits water out between the strainer basket and the motor. I know this is something new and never has happen before.
    Maybe some of my bubbles are from this area on the pump that spits out the water when I turn it on.
    The cantilever is the edge around the inside of the pool that is part of the decking.
    Jul 2006
    I dont think water spitting out is normal. I assume its just on startup. Maybe its the initial pressure getting past the o-ring seal.I have the pentair superflo 1.0 hp and I dont see any water spitting out anywhere.
    Guelph, ON, Canada.
    Canuck is right, my water spitting out of the cover is not an apples to apples comparison of your problem.
    You shouldn't be seeing water at a bolted joint.
    Depending how comfortable you feel, check the tightness of the bolts at this joint and torque as required. If they are already tight, remove them and examine the O-rings/seal at the joint, and reassemble / retighten.
    Carl Schnurr
    Central Florida
    I have tighten the bolts some and this seems to have fixed my problem.
    I did call my builder about the hairline cracks that are at the edge around the inside of the pool were the expansion joints are on the
    deck. My builder told me this is normal and the cracks should not get any bigger. Does this sound right?
    Jul 2006
    hairline cracks in concrete are normal, if they start seperating any larger/or one side of the crack is moving up/down from the other then it is need of repair. I would guess anthing less than 1/16 is ok, anything more is not.
    Anyone else have thoughts on this?
    Did you keep your concrete deck wet while it was curing?
  1. Pump problem
    By ksturge in forum Pool Equipment & Operations
    Last Post: 09-05-2007, 05:01 PM
  2. New pump problem
    By rayh78 in forum Pool Equipment & Operations
    Last Post: 06-17-2007, 02:22 PM
  3. Pump Problem
    By ellry99 in forum Pool Equipment & Operations
    Last Post: 06-13-2007, 09:32 AM
  4. Do I need a new pump, air problem
    Last Post: 05-08-2007, 03:25 PM
  5. Help with Pump Problem
    By Ctxman in forum Pool Equipment & Operations
    Last Post: 12-31-2006, 01:40 PM
