Results 1 to 4 of 4
Thread: Evaporation rates
    Scottsdale, Arizona
    Default Evaporation rates
    Does water evaporate faster when the relative humidity is lower ?
    14'x31' kidney 21K gal IG plaster pool; SWCG (Saline Generating System's SGS Breeze); Pentair FNS Plus 48 DE DE filter; Whisperflow 1 HP pump; 8 hours hrs; kit purchased from Ben; utility water; summer: none; winter: none; PF:5.7
    California
    Default Re: Evaporation rates
    Quote Originally Posted by Phillbo View Post
    Yes.
    Of course, I might anticipate your next question which is how much faster does water evaporate as a function of the level of relative humidity. As a first approximation and with temperature, air density, and air flow (i.e. wind) held constant, the rate of evaporation is inversely proportional to the relative humidity (RH). So the rate is highest (say, 1.0) with 0% RH and is 10% lower (say, 0.9) at 10% RH, half the rate at 50% RH, 90% lower (say, 0.1) at 90% RH and is 0 (i.e. no evaporation) at 100% RH.
    Richard
    Sanford, FL
    Quote Originally Posted by chem geek View Post
    Yes.
    Richard
    Phillbo......so in other words - when it's pouring there is no evaporation - but when it's really dry...yes you have to top off the pool
    LOL - I'm laughing again - Richard you might like my post on the anti-freeze thread...... I need to get more than 4hrs of sleep a night or I'm going to start getting banned from forums
    Completed 8/21/06
    14,000 gallon 3'-6' concrete pool with Diamond Brite
    Spa with spillway
    250K BTU gas heater (for spa)
    SWCG - Aqua Rite
    Hayward Super II Pump - Cartridge filter
    See pictures here http://www.philsimmons.com/family/ga...mages&keyword=
    California
    Though I answered the question of evaporation rates as a function of relative humidity, I now answer it with respect to temperature. The evaporation rate is proportional to the vapor pressure of water which is a function of temperature. At 20C (68F), the vapor pressure is 17.5 mm Hg; at 30C (86F) it's 31.8; at 40C (104F) it's 55.5
    So as Simmons99 says, "when it's really dry you have to top off your pool" and more specifically when it's 104F outside then, all else equal, water evaporates over 3 times faster than at 68F. In hot desert areas with 104F temperature and RH of 10%, the water evaporation rate is over 5 times as high as the coastal area where I live at 86F and 70% RH (not right now, but back in July). And then there's differences due to wind...
    There are products on the market that act as a liquid "blanket" to lower the rate of evaporation. Such products, typically alcohols such as cetyl alcohol, will cut the evaporation rate by more than half, but you have to constantly replenish this product (even though a little goes a long way since it's only a few molecules thick on the water) and it's putting more organic junk into your pool (more stuff for chlorine to oxidize, etc.). It is generally much better to use a pool cover to significantly reduce evaporation.
    Richard
  1. CYA evaporation
    By jmmctighe in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-03-2010, 07:43 PM
  2. Disinfection Rates and Minimum Chlorine Levels
    By chem geek in forum The China Shop
    Last Post: 01-06-2007, 02:53 PM
  3. Evaporation
    By Rangeball in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-13-2006, 07:15 PM
  4. Evaporation
    By xoroniox in forum Pool Chemicals & Pool Water Problems
    Last Post: 04-27-2006, 11:46 AM
