I have been using Ben's test kit for a while now and have had consitent CYA readings of around 80. Last couple of times I tested I am getting a CYA of 30. So I took a water sample to a local pool store and the report said my CYA is 80. What's going on?
I tried different water samples and even using a different reagent (from my new kit) - same results. I am leaning toward believing Ben's kit because I also find I have no chlorine after the pool sits all night. But I have about 5ppm Chlorine while the pump (and SWG) are operating. Sounds like low CYA doesn't it? I should be able to maintain chlorine overnight - right?
If my test results are correct, where did the CYA go? I put in about 9-10lbs of stabilizer (6 months ago) - into a 18K to 20K pool. My test kit was showing 80 then. CYA is hard to get rid of so I really should have a CYA of 80 now.
I'll try to get another pool store to test my water. Is there anyone else experiencing any test result difficulties? Could I be doing something wrong? Does the reagent go bad? Will the CYA test results be the same if I'm viewing the tube (black dot) inside the house as opposed to viwing in bright outdoor sunlight? What if its cloudy out?
Mike in FL
