Results 1 to 8 of 8
Thread: my chlorine is good but water is green
    SF Bay Area, CA
    Default my chlorine is good but water is green
    Can anyone help me understand where things went wrong for me?
    I've been maintaining the chlorine at about 3ppm with my SWG and things were going great. I had the solar cover on the pool the last three weeks and maybe didn't brush the sides as well as I should. Took the cover off last weekend and found the water is a bluish-green, so it isn't too bad YET. I added 3 gallons of bleach and brushed it well today. Lots of green came off.
    Here are my latest results:
    FC 7, CC 0, TC 7
    pH 7.5
    Alk 90
    Cal 190
    Cya 40
    Temp 80 F
    Salt 3000 ppm per Autopilot recs
    about 27,000 gal IG w/spa
    Polaris cleaner
    Autopilot SWCG
    Pentair cartridge filter
    Jul 2006
    Default Re: my chlorine is good but water is green
    I could be wrong, but I was told that keeping your cover on for any extended period can let the algae start a bloomin.
    SF Bay Area, CA
    Help? Anyone?
    One thing I didn't mention, if it matters. I added the chlorine at about 10:30 AM but didn't do the water testing until about 6 PM.
    Polaris cleaner
    Autopilot SWCG
    North Florida
    river-wear: Having just done battle with algae myself, I feel I can pass along a few thoughts.
    With FC of 3 and CYA of 40, your shock level is 15. Using the Bleach Calculator for your size pool of 27,000, it calculates that you would have needed 5.4 gallons of bleach to raise your FC 12 ppm (from 3 to 15).
    Shock your pool, continue to brush, run the filter 24/7. Test as often as you can, 2 or even 3 times a day if you can manage it and bring that FC level back up to shock each time. It'll clear.
    As to why it happened when your #s look good...maybe CanuckPool is right. Otherwise, algae spores are everywhere, even in "perfect" pools. Algae happens .
    Sandy
    SF Bay Area, CA
    Thank you both for the help. I battled algae earlier in the summer, and you're right about needing more chlorine. I need to pick up some more at the store. Has anyone noticed that the "gallon" size bottles actually only have 3 quarts in them?
    Mostly I was wondering about why the algae grew with 3ppm Cl. Canuckpool must be right about leaving the cover on too long. I didn't realize it would be a problem because last year the cover was on 6.5 days out of 7 - the pool guy (which I don't need anymore thanks to this forum) - would leave it off whenever he came.
    Polaris cleaner
    Autopilot SWCG
    Jul 2006
    We left ours on at the end of the summer for about 4 days in a row, no one was swimming and the weather was overcast. Didnt get any blooms but noticed that my Chlorine level kept going up and up (SWG set at 40%). The Pool store said I should keep the cover off during the day to prevent this especially if no one is swimming, they also mentioned something about having the cover on could cause algae to start. I suspect I didnt get any blooms due to a south facing pool and my pump was running 24/7 at the time. I guess even water needs to breathe.
  1. Chlorine level good, but still green
    By fhorta in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 09-08-2012, 02:51 PM
  2. Raising Chlorine Making Water Green
    By Cookieman in forum Pool Chemistry for Intex-type Pools
    Last Post: 04-06-2012, 11:14 PM
  3. Cloudy green water, with a good Saturation Index
    By Anonymous European in the US in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-27-2011, 02:12 PM
  4. water turns green with chlorine is put in!
    By belldane in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 08-21-2006, 04:47 PM
