Thread: Solar Pool Cover Help. What's the Best?
    Ocoee, Florida
    Default Solar Pool Cover Help. What's the Best?
    We are in the final stages of putting in solar, but have no idea on what is the best pool cover to use. I've seen bubbles or diamond shapes in the cover and 9mil to 16mil covers. Can you all direct us to what you would consider the best cover on the market (where to get one too) and what mil thickness. Oh yes what does the thickness add to the cover, the solar guy has a standard 9mil cover to offer us. I see there is another post to this topic so sorry if some of the things are covered, but I really for some additional recomendations such as type and mil. thickness. Can you also use a reel on a free form pool with lots of curves and recomendations on what type reel? Lastly, how do you cut the blanket to fit the pool?
    15,000 gallon IG free form 16x32 w/attached IG 6x7 spa. Aquapure SWG, Jandy Aqualink 4 w/ PDA, Paramount infloor cleaning system, Starite 400K propane heater, Starite system 3 filter, Starite 2hp pump, polaris D'Light LED pool and spa light and paver decking. Completed in 11 weeks 7/4/06.
    Michigan
    Default Re: Solar Pool Cover Help. What's the Best?
    Fcfrey echoed my thoughts in this thread. I'll never get anything other than the extruded one from poolproducts.com (the SPP site fcfrey mentioned). I've wasted so much money on 'quality' solar covers that didn't last more than 1 season. They'd delaminate, and not roll up on the reel correctly. What a pain! Finally I found the extruded ones, and I'll never go back.
    Read all about what they mean by 1 piece extruded here.
    http://www.poolproducts.com/-p-solarblankets.htm
    Oh, and don't bother to go by length of warranty. Most will claim the failure was due to something you did anyway.
    Why BBB? Because money can't buy happiness, but saving it sure can!
  1. Intex debris cover or solar cover
    By Larryh86GT in forum Pool Equipment & Operations
    Last Post: 06-12-2013, 05:06 PM
  2. Solar Cover Thickness, Reel Quality, Solar Panels
    By vector13 in forum Pool Equipment & Operations
    Last Post: 03-20-2012, 01:45 PM
  3. Solar pool cover
    By GregP in forum Above-Ground Pool Construction & Repair
    Last Post: 02-27-2012, 04:41 PM
  4. Is there a solar cover that is less likely to blow off the pool?
    By cnk in forum Pool Equipment & Operations
    Last Post: 03-28-2006, 04:18 PM
