Closed Thread
Results 1 to 10 of 10
Thread: closing questions?
    Default closing questions?
    I am closing my pool myself this year, always had the pool company do it before. i have read all the posts and you have answered most of my questions. But one thing the pool company never done was blow the lines out. Would you please be very specific and explain to me how to do that. Also, they always added a bioguard winter closing kit which contained Artic Blue Shock and Artic Blue Alagecid. Is there any need for me to use these? does these products contain anything special if the lines are not blow out?
    Thank you
    hzz is offline Lifetime Member Thread Analyst hzz 1 star
    Toronto Canada
    Default Re: closing questions?
    Forget about the bioguard products. You don't need them, and they certainly have nothing to do with blowing the lines out.
    Are you certain the lines were never blown out before? Part of it depends where you live and how cold it gets.
    While every pool is different, the basic idea of blowing out the lines is to remove water from them that may freeze and therefore expand causing damage. I personally use a Rigid vac from Home Depot to blow them out. I disconnect the pipe from the outlet of my filter then blow through it until only air and no water comes out of my return jets. Then I cap the jets off.
    For the skimmer I use the vac to suck the water out of the hole that heads to the pump, then blow back through the hole from the pump to the skimmer to be sure all water is removed. It is then capped with a "gizmo"
    As you can probably tell there are many different ways of accomplishing the same thing, and each pool is very different.
    Hope this gets you thinking along the right lines, anyway.
    Honesdale PA
    I don't know why you deleted the post but you are definitely on the right track. Where you are located you probably don't have to worry about the frost line and freezing underground pipes.
    i didn't think anyone was going to reply.
    so basically just close as i was instructed by the pool person and not worry about blowing out the lines?
    Carl D. had told me in an earlier post to shock to 15 and add poly quat and wait 24 hours, then shock again and close. does that mean close right after it reaches 15 the second time? my pool person never put a gizmo in the skimmer, only thing ever put there was one of the empty plastic bottles of shock. should i do that?
    thanks for your reply and help.
    Honesdale PA
    My guess is where you live you could get surface freeze but nothing deep so the idea of something in the skimmer to take care of surface freeze is fine. You just have to give any ice a place to expand. Up here I get serious freeze and I just pack the skimmer with closed cell foam...same stuff as pool noodles. I've been here almost 10 years and for the previous 20 years of the pool I'm sure it wasn't taken care of the way I do it.
    Think Spring.
    kacy is offline ** No working email address ** kacy 0
    I'm in a similar situation. I have a 25K gallon inground pool. Have been paying a pool company to close my pool for the past two years and would like to do it myself this year. I'm pretty sure the pool company has never blown out my lines either or drained below the skimmer. They drain the pump and filter and remove the pressure valve (I assume they drain the chlorinator also). They also put some kind of plastic bottle in the skimmer. Then they just put on the loop lock cover. I live in Northern Alabama and I'd bet the Frost Line is such that underground freezing temperatures aren't an issue. Do you think I'm on the right track?
    Thanks.
Closed Thread
  1. IG pool closing questions
    By gogolion in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 11-29-2012, 02:02 PM
  2. first time pool owner and first closing (still with questions)
    By rannrich in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 11-14-2011, 06:30 PM
  3. Read the stickies/Still have closing questions.
    By anixon7 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 10-27-2011, 10:42 AM
  4. A few odd pool closing questions....
    By revhendrix in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 11-04-2006, 07:35 PM
  5. Questions About Closing an IG Pool
    By CelticDaddio in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 10-06-2006, 11:57 AM
