Thread: Help with Jandy RS8 PCB Problem?
    Default Help with Jandy RS8 PCB Problem?
    My pool was installed in 2002 and I believe the Jandy RS8 PC Board died today. At the pool panel, I measure 24 volts comming out of the transformer but no lights or functionality out of the control panel. I checked the fuse and it's good.
    The PC board that I think I need to replace is labeled:
    PCB # PCB8124A
    Assy #8125A
    The Chip is Labeled:
    ALRS8
    P&S
    8156JJ
    Does anyone know where I can get one of these at a reasonable price? Also, I've seen a similar PC board on ebay but it is for the RS6. Are they compatible? What should I look for on the replacement PC board to know that it's the correct one?
    Thanks for your help!!
    John
    Default Re: Help with Jandy RS8 PCB Problem?
    Anyone have any experience with this ??
    How did you make out ?????
    MY RS8 transformer is blow I hoep nad not the PCB
    I await your reply
  1. jandy 2 speed pool pump problem
    By fordgt in forum --cleanup--
    Last Post: 07-02-2013, 08:43 PM
  2. CVA-24T Actuator on a 3-Way Jandy Valve Problem
    By JMarko in forum --cleanup--
    Last Post: 01-05-2013, 04:43 PM
  3. Jandy pump problem
    By Bergerman in forum Pool Equipment & Operations
    Last Post: 05-29-2007, 07:32 PM
  4. Jandy Aquapure SWG Circuit Boad Problem
    By guild1 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 09-23-2006, 11:29 AM
  5. Jandy SWG problem?
    By jayamberly in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-16-2006, 01:11 PM
